After 5K, weak pull, broken o2 sensor?
Old Mar 24, 2002 | 06:42 PM
Ri5e's Avatar
Default After 5K, weak pull, broken o2 sensor?
MY friensd car, a turbo integra gsr with a T3 turbo, feels good from 1k to 5k. After that, it falls flat as though there is no turbo. Could it be because of a broken O2 sensor? 2 weeks earlier, the car pulled really hard throughout the RPM, but then he hit a speed bump and the o2 wires got ripped out from the clip. He put them back in but it might be in wrong. Could the O2 sensor cause this problem?
Old Mar 24, 2002 | 06:49 PM
zip's Avatar
zip
Default Re: After 5K, weak pull, broken o2 sensor? (BG Boost)
If the motor falls flat during WOT then the O2 sensor is fine since the ECU ignores the O2 sensor outputs at wide open throttle. The ripped O2 sensor wires, caused by the speed bump, might be shorting causing erratic ECU operation.
Old Mar 24, 2002 | 06:53 PM
Ri5e's Avatar
Default Re: After 5K, weak pull, broken o2 sensor? (zip)
It wasn't really WOT. More like just 60% throttle, to redline.
Markadler47@gma
Mar 22, 2019 02:36 PM
dragaholic
Dec 23, 2005 05:03 PM
gitwidit
Mar 10, 2003 10:36 AM
