Afr adjustment
Old Jun 5, 2024 | 12:19 PM
Bennyrosenblum's Avatar
Default Afr adjustment
Finished putting on turbo and when I start the car it sits around 19 afr when we were trying to tune it and add fuel to get it to a normal afr the idle would get very rough and sound like its flooding the engine anyone know what the problem can be
Old Jun 5, 2024 | 01:40 PM
liam821's Avatar
25 Year Member
Default Re: Afr adjustment
Can't help without knowing more about the setup. I'd think your tuner would be more helpful here.
Old Jun 5, 2024 | 08:56 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Maybe you have an exhaust leak ahead of your A/F sensor that is pulling outside air into the exhaust system corrupting the A/F values.
Old Jul 3, 2024 | 02:44 AM
wunfstgsr's Avatar
Loved
Community Favorite
Have you tried using a base map?
make sure the parameters are correct for the fuel injectors, dead times and injector size with the EMS you are using.
lsvtaksauce
Apr 29, 2013 11:55 AM
busyychild
May 11, 2007 05:13 AM
winterbear09
May 4, 2004 10:11 AM
turbogsr
Dec 1, 2001 08:05 AM
