AEM users and tuners
Old May 11, 2004 | 04:46 PM
done's Avatar
Default AEM users and tuners
My ems wont connect to my laptop. im using a usb to serial adaptor, does that matter?
coms are setup correctly
Old May 11, 2004 | 04:58 PM
99B16Si's Avatar
Default Re: AEM users and tuners (Jordo)
i tried an adapter once and it didnt work for me either. there maybe a certain way to make it work but i had to find a laptop with the correct serial port to get it to work.
Old May 11, 2004 | 05:05 PM
93accordNOS's Avatar
Mine works with a USB to Serial adapter, the one I use is the keyspan high speed model.
Old May 11, 2004 | 05:19 PM
done's Avatar
Default Re: (93accordNOS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93accordNOS &raquo;</TD></TR><TR><TD CLASS="quote">Mine works with a USB to Serial adapter, the one I use is the keyspan high speed model.</TD></TR></TABLE>
i was using a belkin, did you have to do anything different to make it work? im gonna exchange mine tomorrow. and try the keyspan
Old May 11, 2004 | 06:30 PM
Didn't need to do anything special, I had to use com4 which was strange, but other than that it worked fine. Should be a small black box with a silver cable, if that helps you find it.
Old May 11, 2004 | 10:45 PM
SiRkid's Avatar
make sure you have the correct COM/Port!!!!!!!!!
thats a prob I had to begin with too(was also using an adapter)
I think mine is 7
Old May 11, 2004 | 10:57 PM
11psiTurboSI's Avatar
Default Re: AEM users and tuners (SiRkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRkid &raquo;</TD></TR><TR><TD CLASS="quote">make sure you have the correct COM/Port!!!!!!!!!
I think mine is 7</TD></TR></TABLE>
I had that problem too cuz aem is set for 1 and my usb was 4! After that work great with the usb adapter
Old May 12, 2004 | 04:10 AM
boosted hybrid's Avatar
Default Re: AEM users and tuners (9psiTurboSI)
I had a similar problem, I had to install the driver that came with my usb/com converter. Check the port setting, if that doesnt work install the driver if you havent already.
Old May 12, 2004 | 06:11 AM
legendboy's Avatar
Default Re: AEM users and tuners (boosted hybrid)
Yep, I'm using one too. Had to install the drivers from the cd ^
Old May 12, 2004 | 06:22 AM
PM-Performance's Avatar
Did the driver work out for you then Jeff?
Yea if you are Using XP use the drivers that came with the connector. I have the Belkin one too.
Also make sure the com port is correct. mine is set to com4 and works perfect
Old May 12, 2004 | 05:36 PM
done's Avatar
Default Re: AEM users and tuners (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">Did the driver work out for you then Jeff?
Also make sure the com port is correct. mine is set to com4 and works perfect</TD></TR></TABLE>
i got the key scan one, and im gonan try it tonight
com4 . i tryed com1 and 5, not 4
Old May 12, 2004 | 08:06 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jordo &raquo;</TD></TR><TR><TD CLASS="quote">
com4 . i tryed com1 and 5, not 4</TD></TR></TABLE>
My usb also was com 4
Patman
Honda Motorcycles
May 3, 2008 07:56 AM
eg_passion
10
Jan 28, 2007 01:12 PM
Beatkidd
Jan 12, 2004 08:59 PM
mickey513
Apr 23, 2003 04:16 PM
EVIL CETANE
Jun 21, 2002 09:37 AM
