AEM Fuel Pressure Regulator Problems
Mine withstood many visits to 110 psi, but my friend broke his (the internal diaphram) with about 95 psi. Filled the intake manifold/JR charger with gas and he had to let the engine dry out for about a day. Luckily, no damage. He tore a 2nd diaphram with about 80 psi, but he caught it before it completely ruptured like the first one.
This was a known problem with the "early" AEM FPR's. Apparently, they have taken steps to correct to correct this by using a beefier diaphram.
I never had a problem with mine and my friend is now on his 3rd diaphram and hasn't had a problem with, but's running a Hondata now with peak fuel pressure around 55 psi.
Sonny
Sonny
Mines still sitting in a box on the other side of the room.... waiting for aem fuel rail, new fuel pressure gauge, and till I can afford injectors until I put it in... My goal is to get my fuel system DONE and tuned after all the above listed are in my room.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sonny »</TD></TR><TR><TD CLASS="quote">Mine withstood many visits to 110 psi, but my friend broke his (the internal diaphram) with about 95 psi. Filled the intake manifold/JR charger with gas and he had to let the engine dry out for about a day. Luckily, no damage. He tore a 2nd diaphram with about 80 psi, but he caught it before it completely ruptured like the first one.
Sonny</TD></TR></TABLE>
did a search and this what came up,
where did he buy the diaphram to reservice the aem regulator and how much?
i have had mine almost since they came out and the only prob i had was my fault, i put in my walbro 255 and the orig orffice couldnt handle it and caused diphram flutter and caused cels for missfires, i changed to a bigger one and cleaned up the prob.
i have taken it up to 100 psi already by accident for a while
This thread is back from the dead
..just to update what I did,heard too many stories about the AEM so I sold it and got a aeromotive reg
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 »</TD></TR><TR><TD CLASS="quote">i have had mine almost since they came out and the only prob i had was my fault, i put in my walbro 255 and the orig orffice couldnt handle it and caused diphram flutter and caused cels for missfires, i changed to a bigger one and cleaned up the prob.
i have taken it up to 100 psi already by accident for a while</TD></TR></TABLE>
Which orifice should I use with a Holley 255lph high pressure pump? The .100, .150, or .200?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Man »</TD></TR><TR><TD CLASS="quote">. . .so I sold it and got a aeromotive reg
How much can the Aeromotive be had for?
</TD></TR></TABLE>How much can the Aeromotive be had for?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 »</TD></TR><TR><TD CLASS="quote">
Which orifice should I use with a Holley 255lph high pressure pump? The .100, .150, or .200?</TD></TR></TABLE>
i was told my AEM to use the .150 and that fixed the prob.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AVATAR »</TD></TR><TR><TD CLASS="quote">
How much can the Aeromotive be had for?</TD></TR></TABLE>
they run around $129-139.It was about $50 less then what I payed for the AEM and personally I feel its better made.
i was told my AEM to use the .150 and that fixed the prob. </TD></TR></TABLE>
Thanks
Thanks
superturboprelude
Jul 10, 2007 06:04 PM
