<<< AEM EMS Tips >>>
Old Mar 20, 2002 | 12:37 PM
philo's Avatar
Default <<< AEM EMS Tips >>>
Please post any undocumented tips that helped you get your EMS going.
Old Mar 20, 2002 | 12:38 PM
philo's Avatar
Default Re: <<< AEM EMS Tips >>> (philo)
Here one for starters:
To prime the pump you need to go OPTIONS --&gt; FULL LIST --&gt; LS11 Fuel Pump (ON).
Old Mar 20, 2002 | 12:52 PM
philo's Avatar
For those with a light weight fly wheel and A/C, you may need to increase the IAC duty cycle so you don't stall when your A/C kicks in. Try setting this parameter:
OPTIONS --&gt; IDLE --&gt; IDLE JACK (-10)
Depending where your idle is set you may want to experiment with different values.
Old Mar 20, 2002 | 01:51 PM
kamlude's Avatar
If car does not idle properly, check to see what injectors are selected. On my prelude you need to select injectors 1,2,3,4 but on a newer integra you need to select 1,2,4,5. I was told this is because the newer integra ecu is based off a v6 ecu. Remember to change the injector syncs aswell.
Old Mar 20, 2002 | 01:56 PM
kamlude's Avatar
Default Re: <<< AEM EMS Tips >>> (kamlude)
Pin output for IAB on gsr,prelude is pin 26. i belive it is a Low Side (LS).
Old Mar 28, 2002 | 03:50 PM
quick108's Avatar
If you want to make the check engine light (CEL) a shift light, go into the options menu and find LS10.
Alt ON (turns LS10 options on)
Cool Hi ON (makes the CEL active above the Cool value)
Load Hi ON (makes the CEL active above the Load value)
Speed ??? (set this RPM value to trigger the CEL to come on)
Speed Hi ON (makes the CEL active above the Speed value)
TP Hi ON (makes the CEL active above the TP value)
DONE!
Old Mar 28, 2002 | 08:22 PM
PressurizedSi's Avatar
Default Re: <<< AEM EMS Tips >>> (quick108)
Great Tips keep them coming!!! Question: How quickly does your engine start up? Mine takes about 4-5 cranks before it starts. Before with the blue box it only required 2 cranks. How about you guys? I checked the LS11 and its turned on.
Old Mar 28, 2002 | 10:25 PM
98Psi ITR's Avatar
Default Re: <<< AEM EMS Tips >>> (PressurizedSi)
Keep an eye on their website in the next few days.
hondacurious
Engine Management and Tuning
Jun 28, 2011 01:39 PM
8YourV8
Nov 17, 2006 11:57 AM
dystro
Jan 30, 2006 11:22 AM
boostng r
18
Jan 10, 2005 10:07 PM
Jim S. '95 Z28
Apr 22, 2002 08:30 AM
