AEM ems for obd-0
Old Sep 28, 2003 | 03:04 AM
CiViC SiR's Avatar
Default AEM ems for obd-0
how can i run AEM ems on 91 crx obd-0 boosted?
should i change to obd-1 or i can find an adabter to convert from obd0 to obd 1
Old Sep 28, 2003 | 03:59 AM
slywfbpsi's Avatar
Default Re: AEM ems for obd-0 (CiViC SiR)
you have to run an odb0->obd1 conversion harness, but you can either use the odb0 dizzy http://forum.aempower.com/bbs/viewtopic.php?t=1780 or wire in a odb1 dizzy.
Old Sep 28, 2003 | 04:11 AM
Blown90hatcH's Avatar
Default Re: AEM ems for obd-0 (slywfbpsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slywfbpsi &raquo;</TD></TR><TR><TD CLASS="quote">you have to run an odb0-&gt;obd1 conversion harness, but you can either use the odb0 dizzy http://forum.aempower.com/bbs/viewtopic.php?t=1780 or wire in a odb1 dizzy.</TD></TR></TABLE>That is correct. You can keep the OBd1 distr and run my conversion hanress with the AEM.
Convert your OBD0 car here
Old Sep 28, 2003 | 06:09 AM
racerxadam's Avatar
Default Re: AEM ems for obd-0 (Blown90hatcH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown90hatcH &raquo;</TD></TR><TR><TD CLASS="quote">That is correct. You can keep the OBd1 distr and run my conversion hanress with the AEM.
Convert your OBD0 car here</TD></TR></TABLE>
I used one of Jason's harnesses to convert mine to obd-1 aem ems.
Old Sep 28, 2003 | 08:07 AM
Sikocivic's Avatar
Default Re: AEM ems for obd-0 (racerxadam)
Can you use the OBD-0 dist if you are going to Hondata? I have a turbo DOHC ZC in a 90 hatch. I am looking at upgrading from the FMU and check valves. I am looking at Hondata but there are no OBD-1 dist that will fit the ZC motor. I could use Zdyne but thats going to cost over $900 . Is there any way to get the Hondata to work on the DOHC ZC?
Old Sep 28, 2003 | 07:42 PM
racerxadam's Avatar
Default Re: AEM ems for obd-0 (Sikocivic)
you can probably use a pr3 ecu with the zc
Old Sep 28, 2003 | 08:28 PM
Mase's Avatar
I have tried using aem w/ an obd0 car, we used one of jason's harness' worked good except two of the dizzy wires were backwards, took us about 3 hours to figure out why we were getting no spark/fuel from the aem unit. However, the aem really doesnt like the obd0 dizzy, so we switched to a obd1 dizzy, and had to reverse the two dizzy wires back, and it was much better. but its no walk in the park, for using the aem w/ obd0. thats for sure, but its certainly do-able
shortshift89
Aug 30, 2007 05:05 PM
koleslaw
Mar 24, 2007 09:39 PM
Mo_Spec
Oct 17, 2004 09:09 AM
HCivic45
Jun 25, 2004 05:55 AM
anthony702
Aug 23, 2003 09:43 AM
