AEM EMS dyno results
Old May 31, 2002 | 09:55 PM
turbo Si's Avatar
Default AEM EMS dyno results
I had my 99' turboSi tuned yesterday. These are not my final results due to lack of fuel. I made 254whp and 205lbs torque at 14psi at 6500rpm. Like I said there was a lack of fuel because after 6500rpm it fell flat on it's ***! I felt kinda dissapointed with the horsepower result although it all stopped at 6500rpm when it could have gone to 9500rpm. I also have 9:1 JE pistons which I was told contributed to the low horsepower. I have a set of RC 550cc injectors and a Supra Twin Turbo fuel pump which I will be selling soon and replacing it with an Aeromotive 1000hp external fuel pump, courtesy of my cousins Mustang (thank's Johnny) and a bigger yet undecided size of injectors. So look for a post later! I also had the AVCR which has alot of options although seems pretty suitable so far to use. Lawrence Connley tuned it and I have no complaints with that guy at ALL! He knows his ****! People with AEM do not be discouraged. This is a new system although it is great. As long as you have a good tuner you should be fine. I do recommened getting a wideband though. Like I said these are not my final results although I will post new reults as soon as I make them.
Thank's!
Old May 31, 2002 | 10:35 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: AEM EMS dyno results (turbo Si)
Where is Lawrence Connley located at?
art
Old May 31, 2002 | 10:52 PM
turbo Si's Avatar
Default Re: AEM EMS dyno results (Arturbo)
He's in Houston. He mainly deals with Grand Nationals although I believe he can tune anything that is force induction. Best thing is I believe he is the most knowledgeable guy in town and he only charges $50.00 per hour. He did a friends car with a stock bottom end B16A2 which made 332whp and 215lbs of torque at 12lbs of boost. He had Speed Pro which was easier for Lawrence since he is so familiar with it. I see your going to be in Houston this weekend. I might go.
Old Jun 1, 2002 | 07:08 AM
DA666's Avatar
nice
Old Jun 1, 2002 | 07:29 AM
SiRkid's Avatar
cool!!
Old Jun 1, 2002 | 08:05 AM
littlebluecrx's Avatar
Good #'s but with 550's and a supra fuel pump your car should not have ran at of fuel on 12lbs@6500 rpm, something else is not right. 440's could support that horsepower, 550's should support over 300. Jason
Old Jun 1, 2002 | 09:14 AM
turbo Si's Avatar
Default Re: AEM EMS dyno results (littlebluecrx)
I would have thought so too. The bosst tends to fluctuate up and down at times, but it was mostly at 14psi. I am still learning the AVCR.
Old Jun 6, 2002 | 07:49 AM
Seraph0's Avatar
Oh cool.. You must be talking about TweakedII. And you must be talking about Alex's HB on Speed Pro.
Old Jun 6, 2002 | 08:10 AM
b18tdelsol's Avatar
Default Re: AEM EMS dyno results (MarkC)
Hey turbosi..what are u boosting at?
Jdmefsir12
Nov 4, 2010 09:48 PM
kte324
Feb 3, 2009 05:48 PM
BoostedSi
Feb 24, 2003 08:52 AM
PressurizedSi
Feb 11, 2002 10:19 PM
