AEM boost solenoid question
Old Sep 15, 2009 | 06:31 PM
b00stedOne's Avatar
Default AEM boost solenoid question
To use a AEM boost solenoid, do you have to use AEM EMS to tune your car? or would the solenoid work with ectune?
Thanks
Old Sep 15, 2009 | 06:40 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: AEM boost solenoid question
the aem solenoid is a rebadged mac valve, or it used to be, hell the turbosmart e boost uses the same damn valve.
it is a normally closed valve, it fails closed so you only run wastegate pressure. (atleast it is supposed to and thats what i have been told)
so if the ectune has the ability to run a n.c. valve yes it should work. (i am not familliar with ectune)
i am using that valve with hondata s300.
Bailhatch
Aug 4, 2009 02:54 AM
2 0 3
Aug 2, 2007 05:42 AM
ALL IMPORT
Apr 17, 2007 06:52 PM
JM Performance
Jun 21, 2001 08:22 PM
