Advice on h22a custom turbo setup....
Old Jun 15, 2004 | 08:26 AM
turboH22Aakkord's Avatar
Default Advice on h22a custom turbo setup....
ok... heres the set up. obd 1 jdm h22a (in a 92 accord). ss junk mani, external wastegate set for 5.8 psi (give or take)... vortec 12:1 fmu, inline fuel pump, apexi bov, fmi.... i'm just looking for advice as far as management goes... i know every one will tell me to go standalone with hondata .. but i can't afford that, and if i could i hardly doubt there is anyone near me in Maine to tune it. How well do you think my setup will do ? (or how long should i say) i mean i'm not running all that much boost... if i should get bigger injectors what size should i run? is that a must? and i would need saturated injectors correct? thanks for being pacient with my problems and thanks in advance for your help!!
Old Jun 15, 2004 | 09:33 AM
.dave's Avatar
i HAS questions ?
Default Re: Advice on h22a custom turbo setup.... (turboH22Aakkord)
Ditch the FMU, get some bigger injectors, and go with Uberdata. I know there are some people up in Maine that can help you.
Old Jun 15, 2004 | 09:38 AM
Default Re: Advice on h22a custom turbo setup.... (dtmamg)
id like to do that.. but to be honest with you.. i'm a green as all hell with the Uberdata.. i mean.. i'm good with jeneral mechanics.. but that stuff is way over my head.. is that somethihng you might be able to help me out with?? and any names i could have witht the people in maine?? thanks!!
Old Jun 15, 2004 | 10:15 AM
prelittlelude's Avatar
how far south in maine are you, im very northern mass, right next to nashua nh
Old Jun 15, 2004 | 10:38 AM
Default Re: Advice on h22a custom turbo setup.... (prelittlelude)
i'm pritty much right in central maine.. almost in bangor to be exact.... i live exactly 4 hours from boston....
Old Jun 15, 2004 | 12:02 PM
ludelvr's Avatar
Yah man, I say ditch the fmu and get uberdata and some dsms. That's what I did. Take out the inline if you want as well, but I basically ditched the jrsc fmu and threw in a set of dsms sthat I got for 50 bux canadian and got a p28 ecu for 80 dollars canadian and chipped for 50 bux and some dyno time and it's running a HELL OF LOT BETTER! Seriously man, it'll be way worth the time to do this and more tunibility, I even have full throttle launch now!! So sweet! haha
Old Jun 15, 2004 | 12:30 PM
Default Re: Advice on h22a custom turbo setup.... (ludelvr)
its a jdm h22a in a 91 accord.. if i use dsm injectors.. wont' i need a resistor box?? thanks again!
Old Jun 15, 2004 | 10:13 PM
ludelvr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboH22Aakkord &raquo;</TD></TR><TR><TD CLASS="quote">its a jdm h22a in a 91 accord.. if i use dsm injectors.. wont' i need a resistor box?? thanks again!</TD></TR></TABLE>
are you using an h22a1 or h22a4? If you're using an a1 then no, you just use your stock resistor pack, but if an a4 then yah, you'll have to wire one up, it's easy though man, it'll take you 15 minutes or so. I did on a 5th gen lude, just a bit of a hassle to get to but it's fine. I wouldn't go boost crazy with the 450's though cuz they won't support high hp numbers.
Old Jun 16, 2004 | 07:50 AM
haha.. yeah i have a jdm h22a1 in a 1992 honda accord lx.. and like i said.. i'm only planning on running the 5.8Lbs ... (for now )
do you have any other advice on the standalone.. or how to go about getting it?? thanks!!
pcguy760
Jul 1, 2008 09:18 AM
raysjdmh22a
Apr 5, 2006 08:38 PM
superturboprelude
Sep 10, 2005 04:54 PM
RHD_BB4T
May 3, 2003 03:58 PM
