ACL bearings?
Old Mar 16, 2005 | 07:37 PM
bamboosted's Avatar
Default ACL bearings?
Who's used them and what u think of them? Should i use them YES or NO... And for instance if u spin a bearing and able to machine the crank won't you need a thicker bearing for that one ?
Old Mar 16, 2005 | 07:42 PM
drvfast's Avatar
Default Re: ACL bearings? (BamBoOsteD)
I would say no.
Old Mar 16, 2005 | 08:21 PM
BodyKits NW's Avatar
Default Re: ACL bearings? (drvfast)
I've always used OEM bearings, but on my last build I used the ACL's.
Here is the thread. https://honda-tech.com/zerothread?id=765604
They were dead on, and just like Rocket, Earl, Vince, and more have said..they work!
I'll continue to use them unless for some reason they fall way out of spec. But they were exactly where I wanted my clearances to be.
Old Mar 16, 2005 | 09:13 PM
bamboosted's Avatar
Default Re: ACL bearings? (BodyKits NW)
ACL is fairly new to me.And im build a motor some time soon and look at ACL's right now
I used OEM one and i never had any type of problems if there was the was the usally next size up and if the was no thicker then u were in trouble..
Old Mar 17, 2005 | 04:17 AM
g2turbo's Avatar
I have the ACL's as well. Ill be assembling in about a month. But all the research and reading that ive done leads me to beleive that they will work just fine.
Just plastigauge and check clearences.
Old Mar 17, 2005 | 08:25 PM
bamboosted's Avatar
Default Re: ACL bearings? (g2turbo)
any one else bump
Old Mar 17, 2005 | 09:24 PM
omahaturbocivic's Avatar
Work fine for me. Plenty of threads on this if you search and almost everyone will say they are fine.
Jdm_Ej8_Sedan
Jan 29, 2014 05:34 AM
SwagNationEK9
Nov 13, 2013 02:47 PM
fro20
Aug 14, 2007 02:28 PM
akura404
Jul 31, 2006 01:18 PM
totalimpact
Nov 11, 2003 06:39 PM
