Which AC wire to jump for 2 step in Uberdata/Crome?
Old Apr 19, 2007 | 05:21 PM
EJ1 wilcox's Avatar
Default Which AC wire to jump for 2 step in Uberdata/Crome?
I removed my complete AC system, but left the wiring in tact. So I burned a map with a 2step (enabled the AC activation on the 2 step), pushed the ac button, put the pedal to the floor, and it didn't cut when it was supposed to.
I've been doing some reading and read that I need to "jump my AC harness" so it activates the 2 step when I hit the AC button.
Which wires do I need to jump?
Old Apr 19, 2007 | 05:52 PM
adseguy's Avatar
Default Re: Which AC wire to jump for 2 step in Uberdata/Crome? (EJ1 wilcox)
You need to ground it. I believe it's D14? I donno it's been a while. I know it's on the Uberdata forums though
Old Apr 19, 2007 | 07:12 PM
bigbadboy's Avatar
bump for an answer because i want to use the ac button for my boost control
Old Apr 19, 2007 | 07:35 PM
ndogg's Avatar
there is a plug under the hood behind the passenger headlight you have to jump and one under the dash where the ac radiator thing is... i can't remember any specifics either. the info is somewhere on the uberdata site.
Old Apr 19, 2007 | 07:38 PM
nowtype's Avatar
Default Re: Which AC wire to jump for 2 step in Uberdata/Crome? (ndogg)
b5
Old Apr 19, 2007 | 07:46 PM
ndogg's Avatar
Default Re: Which AC wire to jump for 2 step in Uberdata/Crome? (nowtype)
i found some old pics of that might help. i don't remember which ones are jumped in the plug but its something. in the dash pic, you can't really see but there is a jumper behind the metal in the pic.
Old Apr 19, 2007 | 08:02 PM
bigbadboy's Avatar
ok so jump 2 wires in the plug in the engine bay. and jump the plug that goes where the little rad for the ac is??
Old Apr 19, 2007 | 08:20 PM
EJ1 wilcox's Avatar
Right on man, thanks for the pics. I have an EF, but I would think the process would be similar. I know right where both those plugs are.
Thanks!
Old Apr 20, 2007 | 09:16 AM
EJ1 wilcox's Avatar
Does anyone know where it talks about how to do this?
I can't seem to access the Uberdata site and I can't find any info on pgmfi.org either.
Old Apr 20, 2007 | 09:31 AM
SPOOLINmatt's Avatar
what the hell i just set the launch control in crome to 1 mph and it was always doing my launch limiter when i wasnt moving, no need for a switch to deal with.
Old Apr 20, 2007 | 06:47 PM
EJ1 wilcox's Avatar
Default Re: Which AC wire to jump for 2 step in Uberdata/Crome? (SPOOLINmatt)
Okay I think I located my plugs, I have an EF so it's a bit different from the pics.
I just have one question. I have two plugs in my engine bay that are disconnected now that I removed my ac.
Both plugs have two wires to them, one plug is for the AC fan, and the other plug goes to some sort of switch that was on one of the AC hard lines.
Is it the AC fan switch that I need to jump? Or the other switch located on the hardline that I need to jump?
I took pics of the plugs that I'll post up later if I don't determine which it is.
Old Apr 21, 2007 | 02:49 PM
EJ1 wilcox's Avatar
** figured it out **
For future referrence, it's the pressure switch that you jump in the bay.
I jumped the pressure switch in the bay, then the two wire harness under the dash, and it works perfectly.
So yeah, you don't have to jump the fan switch, just the pressure switch.
I will be so nice to be able to build boost for my launches.
Old Apr 21, 2007 | 04:38 PM
ndogg's Avatar
Old Apr 22, 2007 | 08:34 AM
bigbadboy's Avatar
can anyone tell me where the pressure switch in the engine bay is located on a ek??
Old Apr 22, 2007 | 10:19 AM
EJ1 wilcox's Avatar
Default Re: (bigbadboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigbadboy &raquo;</TD></TR><TR><TD CLASS="quote">can anyone tell me where the pressure switch in the engine bay is located on a ek??</TD></TR></TABLE>
On my car, there are two plugs in the front of the car by the passenger side headlight. One of my plugs was green and plugs into the AC fan, and the other plug was white and plugs into a switch on one of the hardlines.
Also, on my pressure switch both of the wires were blue with red on them. They were both the same color. Same with the ones I jumped under the dash, they were both the same color.
Hope that helps!
Old Apr 25, 2007 | 09:58 PM
GetawayInMoscow's Avatar
Default Re: (EJ1 wilcox)
So you do this and then you can use the A/C button to turn on and off the 2-step in crome?
Old Apr 26, 2007 | 05:11 AM
ndogg's Avatar
Default Re: (GetawayInMoscow)
its for uberdata, i don't think crome has that option.
Old Apr 27, 2007 | 09:21 AM
EJ1 wilcox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GetawayInMoscow &raquo;</TD></TR><TR><TD CLASS="quote">So you do this and then you can use the A/C button to turn on and off the 2-step in crome?</TD></TR></TABLE>
I don't know about crome but it works like a champ in uberdata. I have it set to 5000 RPMs and I can build 5 psi!
Pretty sweet
Dragonsfire
Sep 26, 2018 07:40 PM
MattBernazzoli
Feb 1, 2010 04:28 PM
HI91EFHB
Jan 19, 2010 06:44 PM
kuki22
May 23, 2007 06:09 PM
