ac fan
im in the process of making my dumbtube, and well there isnt much room for anything. i was wondering how much my AC would be affected if i removed the fan. it doesent work at the moment anyway but i plan on fixing it verysoon, but if taking off the fan will make it malfunction, i dont want to do it. let me know by tomorrow guys, i hope to have it done by then. thanks!!
u need the fan to cool the condenser......if u dont have it, then ur a/c is gonna be super hot and i think it might blow ur compressor or something, get a slim fan and put it as a pusher (mounted in front of the condenser)
My turbo setup is ac compatible. When I test fitted everything the stock ac fan was also in the way so I removed it and unplugged the ac connector until i get a slim fan.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by playahwitgame »</TD></TR><TR><TD CLASS="quote">well, how much do you charge for this kit you speak of?</TD></TR></TABLE>
Also do you use a 10" or 12" on the condensor? I was thinking about running the 12" on my dual core civic radiator and then 1 10" in the middle of the condensor? Will that be enough or should you use 2 on the condensor alone?
cosidering that the condensor doesent even have aa fan on it and thet the ac fan is mounted on the radiator, i think it will do even better on the condensor
I did a dual pusher setup this weekend,
Before
Fans
After
I would like to relocate or move the main AC line that is above the header. The AC line infront of the header makes no sense to me, it just does a "ramhorn" type loop.
**Update**
I moved the passenger side slim fan back to the oem spot. Its to hot out here.
Before
Fans
After
**Update**
yea my radiator slim fan is fine. th ac fan is what i removed today so i can get a slim fan, so as soon as the fan was out. mt dumptube was made flawlessly
Guest
Posts: n/a
what size would fit on the condensor? Cause Like I said I want to get a half size radiator for my integra and will be keeping AC. And was thinking about a 12" on the radiator and a 10 or 12" in the middle of the condensor.
