99 Si with JRSC...
Old Feb 16, 2003 | 08:03 PM
breakneckvtec's Avatar
Default 99 Si with JRSC...
I was just trying to get some personal accounts of those with a JRSC on their Si's that can give me some tips or things to look for. I know the big thing with the kit is detonation, do any of you have tips to get rid of the detonation. I was planning of running the JR BTC and tuining with the SMC. Thoughts? Comments? Opinions?
Old Feb 17, 2003 | 05:48 AM
JICB16B's Avatar
Default Re: 99 Si with JRSC... (breakneckvtec)
i have a 2000 civic ex sohc with the jrsc on it and i had a hell of a time with the detonation i tried alot of things but the only thing that made a noticable difference with the detonation problem was a fuel pump it was amazing what a difference it made hope that helps you out
Old Feb 17, 2003 | 07:45 AM
b16 matt's Avatar
Default Re: 99 Si with JRSC... (b18a1boosted)
bigger injectors msd ignition and a vafc
Old Feb 17, 2003 | 07:53 AM
Zero_son's Avatar
Default Re: 99 Si with JRSC... (b16matt)
Maybe a full standalone and tuning.
Old Feb 17, 2003 | 08:15 AM
Sonny's Avatar
It took Hondata to get my JRSC working to its full potential. If you don't wanna go that route, you must have an upgraded fuel pump (Walbro GSS-342). On top of that, I would get the JR MAP controller.
It will run pretty good with those two items. It will run even better with a properly tuned standalone.
Sonny
Old Feb 17, 2003 | 08:25 AM
keebler65's Avatar
Default Re: 99 Si with JRSC... (Sonny)
or, you could save money and NOT get the fuel pump or map mod, and just buy the SMC Plus. if tuned properly, you would have no detonation. also only $120 compared to hondata. of course it wont work as good as hondata, but for low amounts of boost the SMC is supposed to be great.
Old Feb 17, 2003 | 10:36 AM
Sonny's Avatar
Default Re: 99 Si with JRSC... (keebler65)
SMC+ and DSM450's is another great option.
Sonny
Old Feb 17, 2003 | 10:57 AM
BritSi's Avatar
I have a 99 Si with a JRSC. At 6 psi you shouldn't have a problem with detonation if you retard the timing per JR's instructions. Anything higher than this and a BTC (or even better a Hondata) and hi-pressure fuel pump (and/or larger injectors) are a must. Cooler s/plugs will also help especially in the hotter months. I have been running 9 psi for 6 months now with a BTC, Walbro pump and cooler plugs with no problems. I do not even get any hint of tip-in detonation.
Old Feb 17, 2003 | 12:45 PM
ModAddict's Avatar
Here's a good parts list in the sig.
VVVVVVVVVVVVVVVVVVVVVVV
protopro88
Apr 7, 2011 09:14 PM
gosu08
Jan 10, 2007 05:07 PM
2K Teggy
Oct 16, 2003 06:26 PM
R59
Oct 29, 2002 12:35 PM
Jonathan_ED3
May 8, 2002 05:24 PM
