97 Accord Fuel Pump?
I'm using an inline fuel pump and am not sure where to connect the positive wire from the fuel pump to the car. I have it connected near the fuse box to a wire so that when the key is in the number 2 position it turns the pump on the only problem is that pump stays running. Is that bad or should the pump be constantly running cause i was under the impression that it would run for a few seconds when turned on and the stop.
Modified by nicktagz at 4:44 PM 8/19/2006
