820 wheel horsepower dyno pull
Old Nov 29, 2006 | 09:54 PM
earl's Avatar
Default 820 wheel horsepower dyno pull
We got to make a couple of dyno passes on George Ahads hot rod car a couple of weeks ago. The passes were done on a new Dyno Jet with load capabilities. This dyno uses dual rollers and I was very surprised to see how well it held the horse power with minimal slippage. No CO2 was used on the wastgate and it just ran off the spring. The boost got up to about 25lbs as the wastegate could not relieve the pressure quick enough from the GT42r. We think that about 35-38 lbs will put us at the horsepower we would ultimately like to see.
The owner of the dyno was shocked as he was expecting about 500whp, haha.
Note both rear view mirrors still in place
Old Nov 29, 2006 | 09:57 PM
blundar's Avatar
Are you having boost stability issues, wheelspin or both? Those dynos are mighty choppy.
Old Nov 29, 2006 | 10:01 PM
tony1's Avatar
Default Re: (blundar)
Looks like you need a tuner! lol
Old Nov 29, 2006 | 10:03 PM
Suprdave's Avatar
Looks like it needs some tuning down low...
So it made 820whp @25psi ona GT42R? Sure??
Old Nov 29, 2006 | 10:07 PM
earl's Avatar
Default Re: (Suprdave)
Yeah, the boost was controlling us, nothing but the spring. We really just wanted to see if we were in the ball park with the tune. On other dynos, in the past, we were just ripping the tires loose so were kind of shocked to see the power come up so fast.
Old Nov 29, 2006 | 10:08 PM
wHOAlly's Avatar
who tuned it? what ems?
Old Nov 29, 2006 | 10:10 PM
earl's Avatar
Default Re: (wHOAlly)
James Lin did the tune on a Motec
Old Nov 29, 2006 | 10:11 PM
Suprdave's Avatar
From the looks of the torque curve, it looks like the boost was holding prett steady just on spring. So that's a plus. From the looks of things it does alot of poppin and bangin before it hits fullboost.
Old Nov 29, 2006 | 10:14 PM
earl's Avatar
Good call, it was popping from valve float. A new set of SuperTech springs and retainers are going in that should cure that problem.
Old Nov 29, 2006 | 10:20 PM
tony1's Avatar
Default Re: (earl)
Valve float through the midrange, but ok at high rpm and high boost?
Old Nov 29, 2006 | 10:24 PM
HiProfile's Avatar
Default Re: 820 wheel horsepower dyno pull (earl)
Wait a sec... 820whp at 'just' 25psi??! ANy more info availible on the setup?
Old Nov 29, 2006 | 10:27 PM
earl's Avatar
Default Re: (tony1)
Not sure Tony, but the current springs in the motor are tired. We only heard a couple of pops but sometimes it is the rate of acceleration rather than the rpms that can cause float. I guess we will know for sure after the spring install.
BTW, we are using the 8" diameter PWR barrell I/C and were getting manifold temps at 54F degrees.
Old Nov 29, 2006 | 10:32 PM
earl's Avatar
Default Re: 820 wheel horsepower dyno pull (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">Wait a sec... 820whp at 'just' 25psi??! ANy more info availible on the setup?</TD></TR></TABLE>Pretty basic off the shelf 83mm 9-1 CP/Pauter in a Benson block. The head has a PortFlow valve job with SuperTech parts but not ported yet. It does have Comp Cams but will probably make the switch to Crane roller.
Old Nov 29, 2006 | 10:39 PM
tony1's Avatar
Default Re: (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">Not sure Tony, but the current springs in the motor are tired. We only heard a couple of pops but sometimes it is the rate of acceleration rather than the rpms that can cause float. I guess we will know for sure after the spring install.
BTW, we are using the 8" diameter PWR barrell I/C and were getting manifold temps at 54F degrees. </TD></TR></TABLE>
Main place i saw the problem with that ic was getting heatsoaked at the track. Things happen so fast during a dyno pull that it doesn't heat soak the same.
Was the car using a honda air temp sensor?
Old Nov 30, 2006 | 02:40 AM
BB6-213's Avatar
Great power Earl!
Old Nov 30, 2006 | 04:12 AM
seen4ever's Avatar
Default Re: (BB6-213)
170mph... doing 5th gear pulls I assume?
Old Nov 30, 2006 | 04:56 AM
SPOOLINmatt's Avatar
Default Re: (earl)
with my 6x8 PWR barrel i was seeing consistent 75 degree intake temps at 9500 rpm, really good stuff, that one you have obviously does the job a little better haha.
Old Nov 30, 2006 | 05:44 AM
DaveF's Avatar
Default Re: (SPOOLINmatt)
it took us ~35-38psi to make 820 to the tires..... non intercooled/83mm bottom end/stock gsr cams/
our car hits hard, damn near full boost @ 6k, and stays there.
i do like the color choice though
Old Nov 30, 2006 | 06:10 AM
wade's Avatar
Default Re: (dturbocivic)
hmm
Old Nov 30, 2006 | 06:22 AM
Broken Gearbox's Avatar
holy.
Old Nov 30, 2006 | 07:00 AM
earl's Avatar
Default Re: (seen4ever)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seen4ever &raquo;</TD></TR><TR><TD CLASS="quote">170mph... doing 5th gear pulls I assume?</TD></TR></TABLE>It has a 4 speed Xtrac trans. That was a 4th gear speed.
Old Nov 30, 2006 | 07:07 AM
earl's Avatar
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">
Was the car using a honda air temp sensor?</TD></TR></TABLE>Tony, that is a great point on the heat soak. The only solution is to ice between rounds and run the pump, I suppose. On our new HotRod car, Pat built the icebox around the core to correct that problem.
Old Nov 30, 2006 | 07:11 AM
Redwidow's Avatar
Default Re: (earl)
Dam nice
Old Nov 30, 2006 | 09:43 AM
b18sihatch's Avatar
he was expecting 500whp WITH THAT SETUP LOL just looking at that motor setup i would expect at least what u guys made good deal!
Old Nov 30, 2006 | 10:21 AM
Boostfed's Avatar
New User
GT4202R or GT4276R?
