600 whp need advice.....
do i need to have t4 manifold with twin scroll for 600hp?and what could be the best turbo to use?i did a some research and found 6262 turbo and garett gt35r but can decide which one to get as of now.
No. you don't need a T4 divided housing to do 600.
You can't narrow down what you need until you have:
-Budget to spend
-Journal Bearing or Ball-bearing cartridge
-Garrett or Borg-warner, Precision, or Turbonetics (any preferences?)
We can't answer these for you. you must answer those first before we can help. There is no "best". Only "best for you
-Budget to spend
i want to purchase top mount from afi or boost flow just cant decided if im ok with the t3/t4 flange with single 44mm wg.and for the turbo i want to get journal bearing precision 6262 or 6265 ive seen the price on this parts and im pretty cool with it.and for the intercooler i want to get precision 750 hp.
my engine set up is b18c ge sleeved 84.5mm bore with 10:1 comp arias pistons and crower rods.head is gsr ported and polished with supertech valve train and blox b camshaft.
If the 44mm gate is in the correct place, that's fine. Since you're dedicating for topmount only, you have room, but that's for drag race only.
There are a couple of other alternatives, but they are not v-band turbine housings.
this is a good chart to go off of from evans-tuning
http://articles.evans-tuning.com/200...o-part-charts/
im running a ramhorn with 6265 journal bearing and made 635 so... your on the right track...
bootlegcivic
Dec 20, 2007 08:33 AM
B18C-Hatch
Nov 14, 2002 02:05 PM
