60-100 pull *quick video*
Old Apr 16, 2006 | 10:11 PM
SpeedingHatch's Avatar
Default 60-100 pull *quick video*
So I put the camera in the car to get a 60-100 pull.
Basic Setup:
9:1 b16 with JDM s1 cable tranny shifting at 8100-8200
sc34
1 bar of b00st
2300lb EF chassis without me
http://media.putfile.com/b16_1bar
I didnt brake boost or anything like I normally do. And I seem to lose steam once in 4th
So there you go.
Any opinions? Can I rev out a stock b16 head any higher safely (I assume not)
blah
Old Apr 16, 2006 | 10:27 PM
StylishDOHC's Avatar
Default Re: 60-100 pull *quick video* (SpeedingHatch)
what a/r on the exhaust housing?...if it's a .63 you could probably go a couple hundred more rpm's.....btw--it looks like your gas gauge is moving down throughout the whole vid...
Old Apr 16, 2006 | 10:28 PM
Default Re: 60-100 pull *quick video* (StylishDOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StylishDOHC &raquo;</TD></TR><TR><TD CLASS="quote">what a/r on the exhaust housing?...if it's a .63 you could probably go a couple hundred more rpm's.....btw--it looks like your gas gauge is moving down throughout the whole vid... </TD></TR></TABLE>
its a .63 yes. And I know about the gas gauge, it does that for some reason, then goes back gradually when the car sits
Old Apr 16, 2006 | 10:39 PM
MidShipCivic's Avatar
This is because gas moves. Whooo someone give me that prize!
Old Apr 17, 2006 | 12:27 AM
Tad's Avatar
Tad
I take my d15b vtec up to 8k all the time
i'd assume a b16 could go alot higher than that.
but yeah, look pretty quick,
i'd have liked to see how it does if you'd kept pushing it a bit further
wut kinda tuning r u running on there?
Old Apr 17, 2006 | 06:01 AM
Default Re: (Tad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad &raquo;</TD></TR><TR><TD CLASS="quote">I take my d15b vtec up to 8k all the time
wut kinda tuning r u running on there?</TD></TR></TABLE>
There were cars up ahead and an uphill bend coming up, so I had to slow down.
Tuning wise, I have a Zdyne ecu with laptop.
Old Apr 17, 2006 | 06:08 AM
Zakar's Avatar
Default Re: (Tad)
i'd assume a b16 could go alot higher than that</TD></TR></TABLE>
Thats an expensive assumption..
like stylish said.. you could probably go a few hundred more..
keep in mind dropping a valve means total engine distruction.. thats why upgraded valvetrain is very important if you plan on revving much past stock
Old Apr 17, 2006 | 07:11 AM
Quad-Damage's Avatar
Default Re: (Zakar)
pulls good, got to love that b16a tranny, short *** gears
Old Apr 17, 2006 | 10:12 AM
Default Re: (Zakar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zakar &raquo;</TD></TR><TR><TD CLASS="quote">Thats an expensive assumption..
keep in mind dropping a valve means total engine distruction.. thats why upgraded valvetrain is very important if you plan on revving much past stock</TD></TR></TABLE>
The head was listed as having "ITR/b16 valvesprings pressure matched for the best set". Not sure if that would matter any, so usually I just keep it around the stock redline. I would like to shift later so I could land in the next gear higher though
Old Apr 18, 2006 | 06:47 PM
Zakar's Avatar
well i'm not sure what that means.. if i remember correctly ITR valvetrain is good to 9ish but if it was full itr valvetrain they would list it as so..
its up to you man.. its your engine that is at stake. do you know what retainers they used?
Old Jun 22, 2006 | 01:27 PM
SiR Kid's Avatar
New User
Default Re: (SpeedingHatch)
I revved the car to 9k before you got it, bud. It loved it, and on the dyno, there was no noise, no loss in power, nothing that showed valve float issues.
How'd the pistons look when you took the head off? If there weren't any valve indentions, I'd say shoot for the moon.
cehcivic15
Jul 18, 2008 06:10 PM
joethejoeman
Dec 30, 2006 11:36 PM
01nhbgsr
Feb 18, 2004 06:37 AM
trooper0641
Dec 11, 2003 03:10 PM
