60-1 good choice?
Old Oct 19, 2008 | 02:48 PM
HighRevn's Avatar
Default 60-1 good choice?
I dont know much about this turbo.Im looking at replacing the turbo on my weekend car. Setup is Stock LS block, ported gsr head turbonetics mani, 3inch DP. Looking at making around the 400-450 range on race gas. what does everyone think of this turbo....again this is not a daily it will be used for track and weekend racing. Or is there another turbo in the range of $600 that would be better.
Garrett T3/60-1 w/ .63 a/r
COMPRESSOR SPECS: T04S housing
Flow: 61 lbs/min 781cfm
.70 A/R housing
60 TRIM wheel
TURBINE SPECS:T3
.63 A/R housing 4 bolt exhaust
HIGH FLOW 76 TRIM stg 3 wheel
oil lubricated centersection.
for use with external wastegate.
comes standard with 360 degree thrust bearing
Old Oct 19, 2008 | 03:07 PM
hbyrd8701's Avatar
Default Re: 60-1 good choice? (HighRevn)
my friend ran high 10s at 22psi on race gas...
Old Oct 19, 2008 | 03:09 PM
Garage 808 Hatch's Avatar
Default Re: 60-1 good choice? (hbyrd8701)
maybe look at the 62-1 or the BW series
Old Oct 19, 2008 | 03:20 PM
wpgredteg's Avatar
Default Re: 60-1 good choice? (Garage 808 Hatch)
that turbo looks good for your set goals.. looks like it is good for about 575whp, check it out http://www.tunertoys.com/Garre...ck=50
Old Oct 19, 2008 | 03:58 PM
HighRevn's Avatar
Default Re: 60-1 good choice? (wpgredteg)
anyone else run one?
Old Oct 19, 2008 | 07:02 PM
Schister66's Avatar
Man U FTW
For your budget, there really isn't anything better that comes to mind. The 60-1 will make 400-450whp; however, a 57 trim is capable of the same numbers. The 60-1 can actually make more than 450whp depending on which turbine wheel you get...
Old Oct 19, 2008 | 07:37 PM
92redhatch's Avatar
i run a bb 62-1 turbonetics turbo on my 84x89 setup and i start seeing boost at 4300rpm.
Old Oct 22, 2008 | 05:14 PM
90lsvcrxva's Avatar
Default Re: (92redhatch)
im running the 60-1 70 trim though. Couldnt ask for a better turbo good ****!!!!
Old Oct 22, 2008 | 11:59 PM
418whpturboD's Avatar
Default Re: (90lsvcrxva)
i run a garrett t3/t61 with p trim wheel.. .82 exhaust housing on my b16 and i love it..
Old Oct 23, 2008 | 01:34 PM
Pman92's Avatar
Default Re: (418whpturboD)
T3 60-1 S Cover all the way. 63 exhaust on boosted h22
Check my sig
Old Oct 23, 2008 | 03:10 PM
eglsbuilt's Avatar
Nice turbo my brother have the t4 60-1
485awhp on a eagle talon
Old Oct 23, 2008 | 05:39 PM
HighRevn's Avatar
Default Re: (eglsbuilt)
just picked up one, thanks for all the input guys
Old Oct 23, 2008 | 06:13 PM
TheShodan's Avatar
Moderator
Default Re: (Pman92)
S covers on 60-1s. bah...
Old Oct 24, 2008 | 03:37 PM
HighRevn's Avatar
Default Re: (TheShodan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">S covers on 60-1s. bah... </TD></TR></TABLE>
Care to explain
Old Oct 24, 2008 | 04:54 PM
TheShodan's Avatar
Moderator
Default Re: (HighRevn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HighRevn &raquo;</TD></TR><TR><TD CLASS="quote">
Care to explain</TD></TR></TABLE>
Not really.. Simply just from my experience with the ones I've made in terms of the ineffective need for the S cover on such a smaller application from its original design.
Modified by TheShodan at 6:05 PM 10/24/2008
Old Oct 24, 2008 | 07:03 PM
HighRevn's Avatar
Lemme guess, you recommend the "silver surfer"?
jdm602
Dec 26, 2008 06:40 AM
AnclyT
Jul 14, 2007 06:18 PM
silverboost
May 24, 2007 10:44 AM
Honda Sport
Jul 16, 2004 04:58 PM
poid
May 5, 2003 09:02 PM
