60-1 or 62-1 which one?
Old Jul 29, 2002 | 09:05 AM
ekb18c's Avatar
Default 60-1 or 62-1 which one?
I have a little question guys. Looking to upgrade my turbo, but I dont know which one would benifit my car more. My options are 60-1 turbo probably with a P-trim, big shaft, hi-fi, BB, or 62-1, P-trim with .84 exhaust trim, BB. What would be better? Looking to push 550whp (for now) for STREET use and sometimes track use. This would be mated on a gsr with 10.1 comp.
Suggestions? Looking for some info.
Thanks
Old Jul 29, 2002 | 09:15 AM
prophet's Avatar
Default Re: 60-1 or 62-1 which one? (ekb18c)
good luck pushing 550hp with 10:1 compression on pump gas.
Old Jul 29, 2002 | 09:29 AM
jinxproof99's Avatar
New User
Default Re: 60-1 or 62-1 which one? (prophet)
yeah, that will never happen.(550 hsp on pump gas)
anyway, sounds like the car will mostly see the street so i'd run the run the ball bearing 60-1.
Old Jul 29, 2002 | 10:49 AM
ekb18c's Avatar
Default Re: 60-1 or 62-1 which one? (jinxproof99)
Yes, the car will mostly see street time, however it will be running on 110 octane from sunoco (cam2). Offcourse the 550whp will be at the track at higher boost, I wouldnt want 550whp on the street. What I meant was 550whp at the track, but I want a turbo that is capable of making 550whp, while still decent on the street. On the street it will be on lower boost level.
Old Jul 29, 2002 | 11:21 AM
boostaholic's Avatar
If you're keeping it mostly street driven, i recommend going with the 60-1.
Old Jul 29, 2002 | 01:30 PM
prophet's Avatar
Default Re: 60-1 or 62-1 which one? (boostaholic)
a 60-1 should be able to produce 550 hp...but again this is what i gather from other people so don't take my word for it...
Old Jul 29, 2002 | 02:24 PM
ekb18c's Avatar
I know a 60-1 will make 550whp but at the same time, for the future, I dont want the turbo to be maxed out when I decide to give it more boost. What the max Hp can the 60-1 make?
TIA
Old Jul 29, 2002 | 04:41 PM
prophet's Avatar
from what i read around 600HP or so.... maybe u should go with the bigger turbo? With the 60-1 the spool up time will be a bitch aready on a t60-1 .63 ar...can't imagine anything that much higher that could be tolerable for street.
PS: actually the best bet is to talk to your tuner...i can't imagine 550hp being an easily accomplished task without a good tuner.
[Modified by prophet, 1:43 AM 7/30/2002]
Old Jul 29, 2002 | 04:52 PM
ekb18c's Avatar
Acutally the spool on a 60-1 is pretty fast if you have it setup the right way. Drove some 60-1's around that spool up at 3k on a 1.8, 10:1 comp. So I'm not worried about spool up time.
Old Jul 29, 2002 | 07:33 PM
hybrid901's Avatar
my 60-1 spools around 4400rpm on my 9:5:1 1.8
RichD14
Nov 13, 2016 12:34 PM
csubucky19
Apr 8, 2009 12:44 PM
fled
Jun 19, 2007 04:04 PM
buck02
Apr 10, 2003 07:48 PM
