Is 6 psi ok?
Old Sep 22, 2001 | 05:04 AM
00 Si's Avatar
New User
Default Is 6 psi ok?
Should someone expect any problems boosting a turbo on an Si to 6 psi daily? Out of a Greddy kit so to speak?
Old Sep 22, 2001 | 05:40 AM
DragII's Avatar
25 Year Member
Default Re: Is 6 psi ok? (00 Si)
6psi is too low, boost at least 7
Old Sep 22, 2001 | 05:54 AM
00 Si's Avatar
New User
Default Re: Is 6 psi ok? (DragIIcivic)
Why 7?
Old Sep 22, 2001 | 05:56 AM
DragII's Avatar
25 Year Member
I'd run 7, or 8 because it's more power, and still perfectly safe.
Old Sep 22, 2001 | 06:05 AM
00 Si's Avatar
New User
safe for what configuration?
Old Sep 22, 2001 | 06:18 AM
DragII's Avatar
25 Year Member
FMU, stock injectors, stock timing
Old Sep 22, 2001 | 06:20 AM
00 Si's Avatar
New User
What about with the Greddy Kit?
Old Sep 22, 2001 | 04:16 PM
BLKMamba's Avatar
BMW Güdentyte
25 Year Member
It's preset to 7-8 psi.
Old Sep 22, 2001 | 04:21 PM
SIK IN DA HED's Avatar
New User
Default Re: Is 6 psi ok? (DB8GSR)
6 psi is ok. that answers your question.. BUT...
boostin 7 is thumbs up! haha
i prefer keepin it between 5-6 for daily driving purposes.
Old Sep 22, 2001 | 04:22 PM
00 Si's Avatar
New User
Default Re: Is 6 psi ok? (dlplayboy)
Yeah but the big intercooler should drop the psi that is why I asked about what to run it at. What is the difference between 6 and 7. 1 whole psi I don't think would make that big of a difference.
Old Sep 22, 2001 | 05:23 PM
DragII's Avatar
25 Year Member
it's not that it will make a big differance, it's more like why not? because you can run 3psi and be safe, but you can also run 7psi and be safe....wouldn't you want 7?
Old Sep 22, 2001 | 05:30 PM
JM Performance's Avatar
But 3 is still safer.
Old Sep 22, 2001 | 05:59 PM
smoothludey2's Avatar
New User
Default Re: Is 6 psi ok? (00SilverLS)
3psi? why even bother installing a turbo then? I make 3psi when i sneeze...
Old Sep 22, 2001 | 06:28 PM
DragII's Avatar
25 Year Member
Default Re: Is 6 psi ok? (smoothludey2)
I feel the same way about 6psi
Old Sep 22, 2001 | 07:11 PM
BLKMamba's Avatar
BMW Güdentyte
25 Year Member
Aaahaahaa!! That's some funny shet.
Old Sep 22, 2001 | 08:35 PM
00 Si's Avatar
New User
What should this net someone on the track (yes I am a decent driver) and on the dyno, just in your opinions
Old Sep 22, 2001 | 10:40 PM
PressurizedSi's Avatar
Track times will vary from driver to driver. With decent traction you should be able to hit low 14's to high 13's, but then again it depends on the driver. 7psi is perfect for the Si. I should know.
Old Sep 23, 2001 | 06:37 AM
00 Si's Avatar
New User
Default Re: Is 6 psi ok? (PressurizedSi)
Is that a pic of your car on your Avatar. If so, why didn't you get a bov? What kind of boost controller do you have, manual or electronic?
Old Sep 23, 2001 | 06:47 AM
00 Si's Avatar
New User
Hey DB8GSR, is the HKS SQV loud?
Old Sep 23, 2001 | 03:19 PM
BLKMamba's Avatar
BMW Güdentyte
25 Year Member
Depends on what you consider loud. Most of the B0V can be adjusted and the HKS makes a whistle amplified sound as oppose to your normal whhooossshhh.
Old Sep 23, 2001 | 03:23 PM
00 Si's Avatar
New User
I mean is it loud compared to say an Eclipse with the same. Eclipses push more boost so they are loud. Didn't know if yours would be. I don't know how much psi you have that is why I was asking. I have heard a couple turbo'd Honda's and their bov's were loud, even on EX's
Old Sep 23, 2001 | 07:50 PM
I'm using the Blitz BOV and Dual solenoid boost controller(electronic). Its a blast to drive with the boost peaking at 7psi. I might raise the pressure later, but not right now.
[Modified by PressurizedSi, 4:51 AM 9/24/2001]
Old Sep 23, 2001 | 07:52 PM
BLKMamba's Avatar
BMW Güdentyte
25 Year Member
Let's say, i turn heads on kids riding their bikes, shifting at 5k.
Old Sep 23, 2001 | 11:58 PM
IgniteTeg's Avatar
Would a Drag 3 turbo kit with its own fuel and everything that comes with it be boostin at what psi to be safe for 01 GSR??? Also would it be loud and noticeable to hear on the street at that boost level for daily driven? Like turn heads?? Thanks
[Modified by IgniteTeg, 1:03 AM 9/24/2001]
Old Sep 24, 2001 | 04:23 AM
4dGSR at work's Avatar
Default Re: Is 6 psi ok? (IgniteTeg)
the exhaust is quieter then w/o the turbo and 6-7 psi you can hear that bov for sure. If you stay below 3500rpm you get a suttle hiss but thats it.
right now i have a drag kit w/ stock exhaust comparing that to a greddy it should be quieter (the greddy that is).
