582whp@25psi
Old Mar 7, 2004 | 04:12 PM
hybrid901's Avatar
Default 582whp@25psi
This is just a safe tune so I could go play Sat night. It needs alot of fine tuning but AF is between 11.2-12.0. Same setup as last year but with a little more head work, PT67 p trim, and a 1.5" log manifold. I stopped at 25psi until I get my fuel system, which I will be getting from Stan on Thursday. Right now all I have is a warlboro 255lph HP and stock lines.
Old Mar 7, 2004 | 04:17 PM
alpha's Avatar
Default Re: 582whp@25psi (hybrid901)
Very nice numbers. I wouldn't mind 400WHP @ 6,000RPM Can you post your old sheet with the SC61?
Old Mar 7, 2004 | 04:40 PM
hybrid901's Avatar
Default Re: 582whp@25psi (0x64)
thanks 0x64
Here is the only graph I have online. Can someone turn it aroudn for me? Its totally pointless on street tires now. It blows the tires off rolling into 5th. Once it starts to spool it comes on so fast.
Setup last year- Now-
b18c1 84.5mm same
10:1 compression same
street/strip head race head
JG Intake manifold same
JG TB same
Spearco IC Precision 750hp
Inline Pro T3 Manifold small log t4 (will be changing soon)
Sc61 .63 PT67 P-Trim .68
780cc Precision 1000cc
hondata same
GSR Cams same
I plan to upgrade the fuel system this week, try some ITR cams, and new turbo manifold.
I dynoed last week with the same setup but with a stock b16 intake manifold and stock throttle body. It produced more mid range tq and the turbo cam on slightly quicker but power went flat around 7500. I will post that graph tomorrow.
Modified by hybrid901 at 2:05 AM 3/8/2004
Old Mar 7, 2004 | 04:47 PM
littlebluecrx's Avatar
nice #'s nobody belived me 2 years ago that a walbro could make 600 hp, now there is some more proof
Old Mar 7, 2004 | 04:49 PM
Soon_2b_evil's Avatar
you did that on pump gas?
Old Mar 7, 2004 | 04:52 PM
alpha's Avatar
Default Re: 582whp@25psi (Soon_2b_evil)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soon_2b_evil &raquo;</TD></TR><TR><TD CLASS="quote">you did that on pump gas?</TD></TR></TABLE>
WTF you been?
I will post the sheet in a minute.
Old Mar 7, 2004 | 04:54 PM
alpha's Avatar
you have full boost at 5300rpms and vtec kicks in at 5500? that bitcOhs goes str8 up. thats sexy.
Old Mar 7, 2004 | 05:04 PM
hybrid901's Avatar
Vtec is set at 4900. Anywhere below that and power would fall and I forgot to move it back to 5100. That dip you are seeing is all tuning.
Old Mar 7, 2004 | 05:06 PM
D-Man's Avatar
nice numbers now update your sig
Old Mar 7, 2004 | 05:08 PM
masterquo's Avatar
bad *** numbers bro!!
Old Mar 7, 2004 | 05:16 PM
SOUNDEFFECTS's Avatar
Default Re: 582whp@25psi (masterquo)
Looks good! What kind of gas 116 vp?
Old Mar 7, 2004 | 05:24 PM
Suprdave's Avatar
Default Re: 582whp@25psi (SOUNDEFFECTS)
Where are you seeing begining of spool, and where are you seeing full-boost?
TurboTegB18c's Avatar
Very nice!
Old Mar 7, 2004 | 05:42 PM
FBP Si 2000's Avatar
Default Re: 582whp@25psi (TurboTegB18c)
Lovely...
Old Mar 7, 2004 | 05:59 PM
TwoK4drSi's Avatar
is that on a stock block?
Old Mar 7, 2004 | 06:00 PM
Suprdave's Avatar
Default Re: 582whp@25psi (TwoK4drSi)
Get Serious...
Old Mar 7, 2004 | 06:01 PM
Blaze45's Avatar
Brrraaaap!
WOW, those are some impressive #s, how pounds of boost do you plan on running once you get your fuel system setup?
Blaze
Old Mar 7, 2004 | 06:02 PM
XLR8 GS-R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TwoK4drSi &raquo;</TD></TR><TR><TD CLASS="quote">is that on a stock block?</TD></TR></TABLE>
hahaha yes it is on a stock soch block
Old Mar 7, 2004 | 06:05 PM
alpha's Avatar
Default Re: 582whp@25psi (Suprdave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave &raquo;</TD></TR><TR><TD CLASS="quote">Get Serious...</TD></TR></TABLE>
What? You dont think cast OEM Honda pistons and connecting rods can handle 582WHP?! Seriously though ... I think he meant to say "sleeves". I hope he did atleast.
Old Mar 7, 2004 | 06:09 PM
WHTZ's Avatar
Default Re: 582whp@25psi (XLR8 GS-R)
Let's see how it goes with the ITR cams...
Old Mar 7, 2004 | 06:16 PM
hybrid901's Avatar
Default Re: 582whp@25psi (WHTZ)
If I remember correctly I see 3psi around 4.5k and 25psi around 6500. I will probably try and make 625 or so. I really plan to run around 24psi and a 75 shot at the track but I will run was much as I can hookup on 25" slick and maybe 26's later on. Yes its c116, the only gas to use.
Irishweird00's Avatar
Banned
What is your fuel setup going to consist of? Killer numbers
Old Mar 7, 2004 | 06:20 PM
lazerus's Avatar
Default Re: 582whp@25psi (Irishweird00)
looking good! Vtec, yo!
does honda even make a 3 cylinder?
Old Mar 7, 2004 | 06:23 PM
alloutmotor's Avatar
damn alot of props to you..thats scary horsepower........
