450 injectors
Old Feb 23, 2003 | 07:57 PM
InTeGrA B18b1's Avatar
Default 450 injectors
how much should i pay for 1g injectors that have been cleaned?
Old Feb 23, 2003 | 08:04 PM
keebler65's Avatar
Default Re: 450 injectors (InTeGrA B18b1)
i got a set of 4, cleaned, balanced, and tested for $125 shipped from mike palm on h-t. he does great work and they even come with a warranty
Old Feb 23, 2003 | 08:05 PM
UberTeg's Avatar
I paid $50 for mine, then paid another $50 to get them cleaned.
Old Feb 23, 2003 | 08:06 PM
Slater's Avatar
I would say $100 is fair - the injectors go for about $30-$50, and cleaning varies widely ($25/set to $100 a set). Some cleanings are better than others (replacing pintile caps, filter baskets, and o-rings for example).
Also, make sure they aren't 1G AT squiters.
HTH,
- Slater
Old Feb 23, 2003 | 08:13 PM
Default Re: 450 injectors (UberTeg)
so you guys say avg around 100.....what was be the worst that can happen if the injectors are not cleaned
Old Feb 23, 2003 | 08:19 PM
keebler65's Avatar
each cyclinder may get a different amount of fuel, causing lean conditions in one or multiple cylinders. as you probably know, a lean condition can be deadly to your motor.
Old Feb 24, 2003 | 08:33 PM
Default Re: 450 injectors (keebler65)
you know any1 selling clips for a 95 integra?
Old Mar 15, 2003 | 07:44 AM
integra6650's Avatar
can you clean your own injectors
Old Mar 15, 2003 | 10:30 AM
mamaboy's Avatar
I just picked up my 450cc's from RRE for $20 each...it was just pulled from a eclipse that day...i have to go and clean and balance them...my room smells like gas...Sonny sells the kits OBD1 clips and the resistors you need
Old Mar 15, 2003 | 11:11 AM
UberTeg's Avatar
You dont need the clips, your car is obd1
Old Mar 15, 2003 | 12:48 PM
LJR-LUDE01's Avatar
I got mine fore 50 dollars but they weren't clean.... when i get a chance I'll get them clean but right now they seen to be running fine
Old Mar 17, 2003 | 12:28 PM
Default Re: 450 injectors (LJR-LUDE01)
ok thanks. what cars need the obd1 injectors? is that for the obd2 right
Old Mar 17, 2003 | 01:12 PM
liam821's Avatar
25 Year Member
i paid $50 for a set of 450s off a 99 GSX. They had been pulled off of my friends car a few days before so i never got them cleaned.
You dont need clips for obd1 cars..only obd2.
And instead of paying $30 for RC clips you can get GM clips from autozone for $10.
liam
maxpsi's Avatar
I paid $30 for mine and $30 more for mike palm to clean them.
eclipsemf
Nov 8, 2016 01:17 PM
marcj
Apr 28, 2008 12:48 PM
ek_99_SiR
Aug 26, 2004 09:09 AM
integra95
Apr 14, 2003 06:56 PM
