4 Inch Mufflers, Do They Really Work??
Old Nov 30, 2009 | 11:48 AM
cjordan's Avatar
Default 4 Inch Mufflers, Do They Really Work??
I have a turbo GSR with VTEC Killer Cams and a GT4088R turbo, I ran 4 inch downpipe and piping underneath the car with a turn down just behind the front seats. It is entirely to loud, do the 4 inch mufflers really work and are there ones that work better than others??? Any help would be greatly appreciated.
Old Nov 30, 2009 | 12:56 PM
SPOOLINmatt's Avatar
Default Re: 4 Inch Mufflers, Do They Really Work??
lol, no they really dont do ****, the only one that might work would be one off a diesel truck.
Old Nov 30, 2009 | 04:15 PM
ebp 99 si's Avatar
u might want to check this 1 out
http://www.aeroexhaust.com/index.php...l-exhaust.html
Old Nov 30, 2009 | 04:24 PM
redboost10's Avatar
run it out the back and youd be suprised how much quiet the cab is actually. everyone thing is echoing under the car as it is right now.
Old Nov 30, 2009 | 04:48 PM
Tony the Tiger's Avatar
Mine works... I have a Magnaflow round muffler in the factory cat location, and a Magnaflow oval body muffler in the back. Sounded like my old 3" system.
Old Nov 30, 2009 | 04:55 PM
redzcstandardhatch's Avatar
something different
we've built several setups in full 4''. with one presiliencer, and one muffler (all perforated core, no obstruction), they were totally quiet going down the road.
LOUD when you get on it.
Old Nov 30, 2009 | 06:44 PM
cjordan's Avatar
Hey Thanks for all the replies! Looks like im going to have to get an exhaust made and run it out the back, I cant deal with it as it is right now. I love the way it cams but geez it gets old in about 2.5 minutes... hahahaha.
Old Nov 30, 2009 | 07:08 PM
my 4" with magnaflow race muffler is LOUD, now its open downpipe i wear full out ear protection muffs when i sit in it to warm it up and when its on the dyno. Its just ridiculous but thats race cars.
Old Nov 30, 2009 | 08:16 PM
B20luda's Avatar
i had an aluminum 4in exhuast (3in DP) full exhuast with no muffler it was super loud.. i decieded to install a muffler... i used the magnaflow 4in round and it made a HUGE difference and sounded much much better
Old Nov 30, 2009 | 09:39 PM
Here's the specs of my 4" system -- 4" round Magnaflow 14162 up front, and a 4" oval Magnaflow 14153 in the back. It's actually very quiet running both mufflers.
Here's a pic:
This is the only video I have of the car running the exhaust:
http://www.youtube.com/watch?v=oPJnFFPA26s
Old Dec 25, 2009 | 02:51 PM
JDM99GSR's Avatar
Here's a pic:
IS THIS THE ONE U HAVE IN THE FRONT ?
http://www.magnaflow.com/02product/d...rtnumber=14162
AN IS THE ONE FOR THE REARS RIGHT?
http://www.magnaflow.com/02product/d...rtnumber=14153
LET ME KNOW THANKS NICE VIDEO BY THE WAY
Old Dec 25, 2009 | 04:05 PM
Casey's Avatar
on a related note....vibrant has an 18" resonator that is a 5" body. that would definitely be a better fit on the underside of a car as far as ground clearance goes, but does lenght dictate how much it quiets the exhaust or does diameter? that 14162 is only 6" long but is also 6" diameter.
Old Dec 25, 2009 | 07:57 PM
Diameter offers more sound deadening, as it allows the sound pulses to travel deep into the baffling material. You can see the trend of quiet mufflers, whether for bigger engines or trucks always have a huge muffler "body". Length is the only second alternative if a larger diameter is not possible.
My ground clearance is acceptable, due to how my piping bends upwards behind the oil pan to compensate for the muffler. The muffler is roughly the same height as the 4" downpipe underneath the oil pan.
Old Dec 25, 2009 | 08:27 PM
Casey's Avatar
gotcha. just dont know how much room i have under the car for a 6" body muffler. ill check the cat area next time the cars in the air
Old Dec 31, 2009 | 07:58 AM
Casey's Avatar
also....are mufflers more effective the closer they are to the source? i think i can fit two under my car that are oval and then run a pipe to the rear of the car if so.
Old Dec 31, 2009 | 01:42 PM
EDwEFprts's Avatar
^ i'd like to know too.
Old Jan 1, 2010 | 12:35 AM
Mufflers will work better with it closer to the source. Closer to the engine means the exhaust gases are also hotter, more volume and sound waves are travelling faster. But you also run into more turbulence and could cause some power loss depending on setup.
There is a key difference I must address properly. Based on what you "hear" inside the cabin versus what the cops hear outside your car, a muffler/resonator that is placed closer to the engine (underneath where you are seated) will make your interior noises louder with more drone, but it will be quieter outside on the outside. Having the resonator/muffler at the trunk, or even sticking out as far out as possible out of the rear bumper will quiet down cabin noise levels but make the car sound louder from the outside.
Old Jan 1, 2010 | 12:59 PM
Casey's Avatar
well im planning to do 2 14153's in 4" in similar locations that you have so im assuming that will be the best of both worlds. as far as losing some power im not too concerned with it at 4" diameter haha
Old Jan 1, 2010 | 08:48 PM
HiProfile's Avatar
I prefer the stock muffler + ecutout. It can be quieter if you want, louder, and in most cases more free flowing. The only problem is that conventional ecutouts suck. I went the custom route and never looked back.
The best part is I don't get cops pulling me over (big prob here), nor any ricers wanting to race me in their I/H/E Accord LX (Intake/hubcaps/exhaust Tip)...
Old Jan 3, 2010 | 11:18 PM
I like E-cutouts as well, but for a nice street driven car, I'd like to have a good sounding exhaust as well as power on tap. The stock exhaust is so restrictive that for any big turbo Honda, you probably won't build boost, make 1-2 PSI so you have to drive around like a granny most of the time.
I had E-cuts before and it was such a hassle to open it up whenever I want to do a pull... Driving around on a daily basis, it's one of those situations which you see a nice empty gap ahead of you (passing someone, or seeing an opening in traffic) and you just want to give it a quick pull. You can't do that with an E-cut unless you leave the cutout open (which will make you go deaf pretty soon..haha).
I have concluded that either running a Varex electronic muffler or an APEXi active silencer was the way to go. Varex only goes up to 3.5" diameter, so it won't be a true 4" though. I only have the Varex on my Camry.
The APEXi active silencer however, has a 4.5" model and I currently have that on my Supra and Integra. The car sounds really quiet at low exhaust flow, but under boost, the silencer valve opens up and the car sounds mean. The Active silencer showed almost no power loss at anything under 650 WHP.
Old Jan 5, 2010 | 11:30 AM
Flr Power's Avatar
Tony,
I am thinking about installing an APEXi active silencer on my Accord.
Do you think the Apexi valve will somehow get sticky in the long run? (carbon build-up)
Will the valve have to be cleaned as opposed to the Varex muffler?
Old Jan 5, 2010 | 12:21 PM
jdkh2006's Avatar
New User
your all gay.
Old Jan 5, 2010 | 04:40 PM
alterdcreations's Avatar
lol
Sean @ ESG
Jul 7, 2006 06:53 PM
GoLowDrew
14
Jul 7, 2006 11:45 AM
Homer_Simpson
Nov 30, 2002 10:51 PM
LoooseGSR
15
Sep 9, 2002 12:52 PM
IVANITR
Dec 17, 2001 05:06 PM
