36 lbs on stock bottom end
Subscribe
Aug 20, 2004 | 08:13 PM
the stock bottom end (never been touched) is a gsr, with a b16a head.
this customer got hold of a potato turbo and wants to run big boost on his engine. a friend told him he cant run more than 8lbs max, but i say his friend is full of ****.
can 36lbs of boost be run on a stock bottom end?
remember, this guy doesnt give a **** about efficiency...just braggin rights.
Reply 0
Aug 20, 2004 | 08:17 PM
Re: 36 lbs on stock bottom end (CallMeJesus)
36 pounds? Christ, is it a diesel?
Reply 0
Aug 20, 2004 | 08:22 PM
Lemme guess. That customer is you.
Otherwise I wouldn't even think about trying it. What else does it have? Fuel setup? Management? etc etc.
Or else, tell him to run 40 psi, then he'll come back to you for a rebuild when he blows his ish up. But I'm not like that...
Reply 0
Aug 20, 2004 | 08:23 PM
Re: 36 lbs on stock bottom end (beepy)
What shop do you work at?
I'll be sure not to ever come there.
Reply 0
Aug 20, 2004 | 08:32 PM
Re: 36 lbs on stock bottom end (BrownDx)
you do that browndx. look at what i said. i said efficeincy is not a concern, just braggin rights.
"Lemme guess. That customer is you.
Or else, tell him to run 40 psi, then he'll come back to you for a rebuild when he blows his ish up. But I'm not like that..."
i like this. good answer, but no, the customer is not me. i personally dont like turbos.
id tune the ecu, make my own adj. fpr, get some dsm injectors and do the necessary work.
Reply 0
Aug 20, 2004 | 08:36 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CallMeJesus &raquo;</TD></TR><TR><TD CLASS="quote">t
can 36lbs of boost be run on a stock bottom end? .</TD></TR></TABLE>
Maybe in his tires.
Reply 0
Aug 20, 2004 | 08:41 PM
Not to be a smart ***, but I doubt you'll find a set of oem dsm injectors that will deliver enough fuel for anywhere near 40 psi of boost, even with your homemade fuel pressure regulator.
Tell your customer you need to build him a motor and it will cost more dollars than sense to do this on a street car.
Also, I vote that you don't post completely rediculous questions on Honda-tech, as there are already more than enough.
One more thing, here's a good book for you..
Reply 0
Aug 20, 2004 | 08:44 PM
Re: 36 lbs on stock bottom end (Arturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">
Maybe in his tires.</TD></TR></TABLE>haha
Reply 0
Aug 20, 2004 | 08:45 PM
36lbs on stock internals with dsm injectors tuned by someone who knows jack...yea sure that will work great just be sure to capture it on film then post it up after the explosion...ha ha
Reply 0
Aug 20, 2004 | 08:53 PM
Re: 36 lbs on stock bottom end (reactiondc2)
Just tell me when there is a danger to the manifold and the floorboard flies off.
Reply 0
Aug 20, 2004 | 08:57 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote">Just tell me when there is a danger to the manifold and the floorboard flies off.</TD></TR></TABLE>ha ha too fast too...............
Reply 0
Aug 20, 2004 | 09:01 PM
1000cc injectors and a 12.1 fmu might do the trick but dont forget the missing link and inline
Reply 0
your jokeing right?
Reply 0
why only 36lbs? go for 100lbs,it will take it.
Reply 0
Aug 20, 2004 | 09:05 PM
Re: 36 lbs on stock bottom end (D-Man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Man &raquo;</TD></TR><TR><TD CLASS="quote">why only 36lbs? go for 100lbs,it will take it.</TD></TR></TABLE>yeah why not go for twin turbo and nawzzzz ...then he will have the ultimate bragging rights...hahahahahaha
Reply 0
Aug 20, 2004 | 09:10 PM
This is some of the dumbest **** I have ever heard. I'm mean yeah it will work great.
Reply 0
Aug 20, 2004 | 09:31 PM
Re: 36 lbs on stock bottom end (hybrid901)
I know someone who is runin 16lbs on a stock Ls block
With a good Compter and chip, some nice fuil work and you could to double numbers.
Reply 0
Aug 20, 2004 | 09:33 PM
36psi??? thats all...
well I was running 82 PSI on my stock R block.. or again was that 8.2psi???
ur a ******* moron plain and simple!
Reply 0
hahahaha
Reply 0
Aug 20, 2004 | 09:49 PM
do it and videotape it... my guess is the headgasket will blow first.... then prolly spin a couple bearings... then crack some ringlands... and if we are lucky throw a rod out the block
Reply 0
Aug 20, 2004 | 10:19 PM
Wait... so this guy read SCC's Project Silvia, went out and bought a Disco Potato(GT28RS) and wants to run 36psi for bragging rights?!?! HAHAHA!!!
You've got to be kidding me!
I don't think a GT28RS could even push 36 psi inefficient or not... Not to mention it won't make any power over about 18-19 psi.
Reply 0
Aug 20, 2004 | 11:22 PM
customer. does that mean u work in a shop? u can run as many pounds as you want its just a matter of how quick the motor blows up. on 36 pounds i give it 2 minutes.
Reply 0
Aug 20, 2004 | 11:32 PM
can 36lbs of boost be run on a stock bottom end? </TD></TR></TABLE>
Yes.... for 1.5 seconds..
Reply 0
you must be the dumbest shop owner ever. I would stick to what you probably know hot to do...installing altezzas and neons
Reply 0
Aug 21, 2004 | 12:13 AM
Re: (soccaian)
his name is "callmejesus" how about "hondantiChrist"
Reply 0
