320whp exhaust size???
Old Aug 10, 2011 | 11:20 AM
88 EF Hatch's Avatar
Default 320whp exhaust size???
Ok so my goal is 320whp. I have a bone stock b16a, with golden eagle fuel rail, aem fpr, 1000cc RC injectors, walbro, t3/t4 50 trim turbo, 2 1/4 IC piping and a 2.5 inch down pipe. I currently already have a full axle back exhaust (2 1/4 piping) with resonator and magnaflow exhaust. Will the 2 1/4 piping I have now hurt me? If I upgrade to 2.5 will it make a huge difference? reason I am asking is cuz before I decided to boost, I had just paid to get my piping redone. And I really like the way it came out and it sounds. Super quiet. and clean look. If the horsepower gain is significant enought I will upgrade to a 2.5 inch exhuast
Old Aug 10, 2011 | 11:38 AM
carnot's Avatar
Default Re: 320whp exhaust size???
Pretty sure you will feel the choke at 2.25" exhaust. I am at the 320whp power level and I have a full 3".
Old Aug 10, 2011 | 11:39 AM
92frostwhtdb2's Avatar
Was the exhaust crush bent or mandrel bent? Not that really matters seeing as 2.25 is too small regardless...the turbocharger in itself has noise cancellation characteristics similar to a muffler so sound isn't going to be an issue..power wise you'll need to upgrade the reason I did ask if it was crush bent though is because u might even need to get 3inch piping seeing as crush bending reduces the diameter of the piping
Old Aug 10, 2011 | 12:14 PM
racebum's Avatar
mandrel 2.5" at a minimum.
lota guys go full 3" at that power and above
Old Aug 10, 2011 | 12:20 PM
4cylfiend's Avatar
Hell I think he could get by with the 2.25" if its mandrel bent and as long as he runs it as a straight pipe with no restriction. Downside is that if and when the OP wants to make power, it will be in a hurt.
Old Aug 10, 2011 | 12:40 PM
LocoJoe's Avatar
Electronic cut out is ur friend.
Old Aug 10, 2011 | 01:41 PM
racebum's Avatar
true, that's the other thing you could do
Old Aug 10, 2011 | 01:48 PM
TheShodan's Avatar
Moderator
^^ This.
Old Aug 10, 2011 | 02:37 PM
SAXON's Avatar
if its stock block you will have a hard time pushing the motor on that exhaust, whereas if its a built block you could probably make that power no problem
the 3" exhaust will just make it more efficient and you wont have to push the motor/turbo as hard to make the power
so is it possible, yes.. is it the most efficient way to do it? no
Old Aug 10, 2011 | 04:13 PM
Hidenplanvew's Avatar
3 inch or ur wasting ur time
Old Aug 10, 2011 | 10:25 PM
wolve's Avatar
tiny exhaust slows spool, run 3" (with ecutout if you must) and enjoy more power and faster spool!!!
Old Aug 10, 2011 | 11:49 PM
98GreenEK's Avatar
I'm running all motor right now but my exhaust setup will remain for the most part the same, i run a 4-2-1 header into a 2.5" delete, then dumped with an ecut, then downsized into 2", 26" glass pack, into a stock muffler with a chrome finisher. The more restrictive exhaust is for quiet operation and low-end torque(when turboed it will help me spool faster at lower rpms so i'm not forced to rod on my car or bog it around town) and also so i don't get annoyed driving places and the stock muffler for floating under the radar of course, but the cut-out helps for high-end power and intimidation of those ***gots in their riced out grand-ams and escorts, in-fact it makes a very notable difference at high rpms and i lose a great deal of low-end also. So what is my advice? keep your current exhaust but upgrade to an electronic cut out for when you do want to make power. Because turbos are choked out with restrictive exhaust setups so you lose a lot of power at high rpms, so low-end torque for cruising, quiet tone...then loud as **** and high-end torque when you give it the nuts. Seriously i can about bet you that you will make probably 20hp upgrading to a cutout just by unrestricting your turbo. That's all, sorry for the long comment.
Old Aug 11, 2011 | 04:54 AM
carnot's Avatar
Not sure what the car inspections are like in Nevada but here in North Carolina I got a bunch of grief over an e-cutout......some law about the exhaust can't be dumped before the rear wheels. It was enough of a pain that I just upgraded to a full 3" exhaust. It was pretty nice having a quiet stock exhaust (catback) and then being able to flip a switch and have the quick spool and power that a cutout provides.
Old Aug 11, 2011 | 06:35 AM
CDecker0218's Avatar
3inch
Old Aug 11, 2011 | 01:34 PM
Ok e cut out sounds perfect and in nevada the laws aren't that strict as far as I know. Know I have never heard of an e cutout till today. Where can I get one? What's a good brand? Relatively easy to install? And can I do an e cutout to 2.5 be good? Or will I need one to a 3 inch?
Old Aug 11, 2011 | 01:47 PM
And how does it work? I can't really tell from the pics. When you hit the switch, does it open up the w.5 side and close the other side? Or does it only open up the big side and let exhaust air flow throught both ur exhaust pipes? Someone explain. Thanks.
bluenc-87
Mar 23, 2010 08:25 AM
SamC
Jul 28, 2003 08:44 PM
DA MUGEN 1
Mar 30, 2003 10:46 PM
TJP_AccordV6
Oct 10, 2002 11:58 AM
mafay2
Mar 11, 2002 04:55 AM
