3 inch exaust spool faster
Old Feb 25, 2002 | 12:07 PM
b18cTurbo's Avatar
Default 3 inch exaust spool faster
i have 2.25 inch full exaust and wonder if 3 inch exaust whit 2.5 inch downpipe would make my mitsu 18 g spool faster or more laggy?.
do we need back pressure to make turbo spool early?
Old Feb 25, 2002 | 12:22 PM
Tomakit's Avatar
Default Re: 3 inch exaust spool faster (mikvtec)
It'll spool faster and be less laggy.
Tom
Old Feb 25, 2002 | 12:45 PM
InfamousRS's Avatar
Default Re: 3 inch exaust spool faster (Tomakit)
How much of a HP gain could be expected from a full 3" DP and exhaust after running a 2.5" DP and 2.25" exhaust? Also how much quicker will the turbo spool up with the 3" setup?
Old Feb 25, 2002 | 01:00 PM
philo's Avatar
Default Re: 3 inch exaust spool faster (BLK94RS)
A turbomagazine article said they pulled a 2.25" Thermal and put on a 3" Thermal and at ~8psi they made 7hp. The real benefits of a 3" wont be seen untill higher boost pressures.
Old Feb 25, 2002 | 01:01 PM
Tomakit's Avatar
Default Re: 3 inch exaust spool faster (philo)
Ask art about his gains after he went 3" dp...he made some good #'s. Or search for it...
Tom
Old Feb 25, 2002 | 02:38 PM
ssblue's Avatar
would a 3in. exhaust cause any lose in hp or tq before the turbo starts to spool or does the earlier spooling make up for it?
Old Feb 25, 2002 | 02:47 PM
*Boostwerks*'s Avatar
Default Re: 3 inch exaust spool faster (ssblue)
No. The turbo it self is a restriction in the exhaust, so a bigger exhaust will not cause a torque or HP lose. Also you wouldn't because the bigger volume allows for a faster spool thus Increasing power.
If you put a 5" exhaust on a turbo system, I don't think You would lose any power. It's just because the turbo is such a restriction in the system.
[Modified by Bryson, 11:48 PM 2/25/2002]
Old Feb 25, 2002 | 03:08 PM
2000_Civic_Si's Avatar
3" Exhaust + Turbo = Good
Old Feb 25, 2002 | 03:11 PM
b18bvudoo's Avatar
New User
old setup: 2.25" dp closed loop, stock cat, apexi RS catback (2.36") -- 181 whp, 169 torque
new setup: 2.75" dp open wg, 3" cat, 3" custom catback -- 202 whp, 179 ft/lb
a lil quicker spool up too
Old Feb 25, 2002 | 03:31 PM
b18cTurbo's Avatar
Default Re: 3 inch exaust spool faster (vudoo666)
nice reply voodoo
thx for your spec
TypeR0149's Avatar
wow thats a nice gain
Old Feb 25, 2002 | 04:04 PM
threatcon13's Avatar
New User
Default Re: 3 inch exaust spool faster (Vegeta)
vudoo why didnt you go w/ a 3" downpipe?
Old Feb 25, 2002 | 04:51 PM
InfamousRS's Avatar
Default Re: 3 inch exaust spool faster (ALLMOTORDC2)
How much power do you loose funning a closed loop setup?
Old Feb 25, 2002 | 04:52 PM
InfamousRS's Avatar
Vudoo, how much boost are you running?
Old Feb 25, 2002 | 05:26 PM
FBP Ex-T's Avatar
what about....if your only gonna boost 8psi?? i mean i have in my sig. 3 in...cause thats what im planning on doing...but i was thinking 2.5 i mean my d/p is like 1.75 then mate that to a full 3 in exhuaast? i dont wanna spend the money on the 3in d/p now....will the 3 in give me less hp then the 2.5?? or more
Old Feb 25, 2002 | 05:44 PM
Hybrid's Avatar
Default Re: 3 inch exaust spool faster (FBP Ex-T)
I'll be running a 2" with no cat, and straight through to a free flowing dual tip stanless muffler. Think this will be ok for 5-6psi?
Oh yeah on my D16Z6/Y8.
Old Feb 25, 2002 | 08:30 PM
b18bvudoo's Avatar
New User
its in my bio, 7-7.5 psi
i didnt go 3" cuz jeff (importbuilders) told me that 2.75" and 3" wont make much/if any difference w/ the boost levels i'm running, 3" would be a tight fit on the 5-bolt flange. i dont plan on boosting more anyways cuz my engine is stock.
Old Feb 26, 2002 | 09:08 AM
. o 69 o .'s Avatar
ok heres my newbie question... what is the difference between closed loop and open ?
Old Feb 26, 2002 | 09:22 AM
dragnGSR's Avatar
Default Re: 3 inch exaust spool faster (B16B)
Closed loop routes the wastegate dump tube back into the exhaust. Open loop dumps into the atmosphere.
Old Feb 26, 2002 | 06:41 PM
InfamousRS's Avatar
Default Re: 3 inch exaust spool faster (dragnGSR)
Do you loose HP running closed loop?
n0pinitr0us
Dec 23, 2004 09:43 AM
Serdar
Nov 18, 2003 06:26 AM
RedStarGsr
Jun 14, 2003 04:44 PM
Lost Type R
May 18, 2003 12:28 PM
gsr sol
Feb 9, 2003 06:19 PM
