3 BAR map sensor
Old Jun 17, 2005 | 01:13 PM
TurboGS-R's Avatar
Default 3 BAR map sensor
I've never bought one before, but I need one to turn the boost past 11 psi on my Integra. I heard that the GM 3 BAR map sensor was around $60 and someone on Honda-Tech said it was $55. I went to GM motors and they said that it is $118.34. That is too much; I could get an AEM 3.5 BAR map sensor for $140. I heard that the "equipment" to make a map sensor can be found at a fish aquarium place and that it's easy to make, but I want a decent "brand name" in case I sell my car.
Where did you guys buy your map sensors and how much did you pay?
Old Jun 17, 2005 | 01:16 PM
dustin's Avatar
Default Re: 3 BAR map sensor (TurboGS-R)
http://www.lightningmotorsports.com/sveharness.htm
at the bottom. $62 and includes connector
And you can't make a MAP sensor at the aquarium store... you can "make" a "MAP bypass" aka check valves, which you really don't need if you are running a 3bar map sensor.
Old Jun 17, 2005 | 01:19 PM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: 3 BAR map sensor (dustin)
http://www.camp1320 for like 59 shipped is the best deal i got , came with harness also
Old Jun 17, 2005 | 01:58 PM
SOHC_MShue's Avatar
How much boost do you plan on running? You can get by with 13psi or so using the stock map sensor by tuning the last column slightly rich.
Old Jun 17, 2005 | 02:53 PM
19sec beast's Avatar
Default Re: 3 BAR map sensor (SOHC_MShue)
Up because I'll be buying one tonight.
Old Jun 17, 2005 | 04:24 PM
adseguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">How much boost do you plan on running? You can get by with 13psi or so using the stock map sensor by tuning the last column slightly rich. </TD></TR></TABLE>
Great suggestion
Old Jun 17, 2005 | 07:32 PM
TurboGS-R's Avatar
More than that. I want to try 15 psi on the street and 18-21 psi at the track.
Thanks guys. The link to camp1320 didn't work, but the other looks nice.
Old Jun 17, 2005 | 08:10 PM
xenocron's Avatar
Get the Motorola 2.5 Bar Map sensor. $18 plus shipping at Digikey...or I have a few too (but not for that cheap)
Old Jul 25, 2005 | 01:36 PM
TurboTeG4's Avatar
Default Re: 3 BAR map sensor (coptzer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coptzer &raquo;</TD></TR><TR><TD CLASS="quote">http://www.camp1320 for like 59 shipped is the best deal i got , came with harness also</TD></TR></TABLE>That sucks I just called them and paid 80 bucks shipped for it
Old Jul 25, 2005 | 01:40 PM
skr TURBO ej's Avatar
gmpartsdirect.com i payed 66 shipped
Old Jul 26, 2005 | 01:25 PM
TurboGS-R's Avatar
Default Re: 3 BAR map sensor (skr TURBO ej)
I bought the one from LightningMotorsports.com. Just a newbie question....Once I install the new map sensor, will I have to retune my Hondata S200B or will it just read the same 11 psi of boost through the new map sensor?
Old Jul 26, 2005 | 01:36 PM
dustin's Avatar
You need to select 3bar and burn a new chip...
and yes some tuning may be required. I've noticed that when going directly from the stock to the 3bar, the voltages don't line up exactly as Hondata planned (or the 3bar precision isn't spot on), so it can mess up your tune.
Old Jul 26, 2005 | 03:51 PM
jBj's Avatar
jBj
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustin &raquo;</TD></TR><TR><TD CLASS="quote">http://www.lightningmotorsports.com/sveharness.htm
And you can't make a MAP sensor at the aquarium store... you can "make" a "MAP bypass" aka check valves, which you really don't need if you are running a 3bar map sensor.</TD></TR></TABLE>
Will this SVE MAP plug into the same spot as my stock one on my 95 GSR if I use the pigtail as well?
Old Jul 26, 2005 | 07:01 PM
mtber's Avatar
Default Re: 3 BAR map sensor (jBj)
http://hondata.com/tech3barmap.html
Old Jul 26, 2005 | 07:14 PM
5thgen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jBj &raquo;</TD></TR><TR><TD CLASS="quote">
Will this SVE MAP plug into the same spot as my stock one on my 95 GSR if I use the pigtail as well?</TD></TR></TABLE>
You will have to wire the 3 wires of the 3 bar into the honda wires...look at the link given above ^^^
you can get an msd 3 bar as well.... same part # as GM 3 bar, which is exactly the same thing.
Old Jul 26, 2005 | 07:47 PM
jBj's Avatar
jBj
Default Re: 3 BAR map sensor (5thgen)
Ok, so this MSD 3 bar in this link with work for my gsr?
http://forums.beyond.ca/showth...t=msd
Also where do you think I could get a 'ac pressure switch' like that one considering this 3 bar for sale doesnt come with a pigtail. Im in canada, we dont have pepboys in my area.
Old Jul 26, 2005 | 07:57 PM
5thgen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jBj &raquo;</TD></TR><TR><TD CLASS="quote">Ok, so this MSD 3 bar in this link with work for my gsr?
You can try some junkyards...."try" some local parts stores maybe.
worse comes to worse you can go straight to gm. do you have a GM dealer?...or you can get the harness from http://www.gmpartsdirect.com GM PART # 15305891
a little pricey for a harness though. But yes thats the same model # I have on my msd...and its the same model # on the GM.
Old Jul 26, 2005 | 08:36 PM
TurboTeG4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboGS-R &raquo;</TD></TR><TR><TD CLASS="quote">I bought the one from LightningMotorsports.com. Just a newbie question....Once I install the new map sensor, will I have to retune my Hondata S200B or will it just read the same 11 psi of boost through the new map sensor?</TD></TR></TABLE>Yeah you have to re-tune from what I hear, buy a new sensor
Old Jul 27, 2005 | 01:17 PM
jBj's Avatar
jBj
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5thgen &raquo;</TD></TR><TR><TD CLASS="quote">
a little pricey for a harness though. But yes thats the same model # I have on my msd...and its the same model # on the GM.</TD></TR></TABLE>
Ok, well that msd one sold. I think I am going to order the SVE 3 bar and pigtail from lightniing motorsports to make it easier. Anyone use one of these before, and/or order for Lightning?
Old Jul 27, 2005 | 03:08 PM
jBj's Avatar
jBj
Also will this sve 3 bar mount into the same spot as my stock MAP sensor?
bump for some more info
Old Jul 27, 2005 | 03:15 PM
dustin's Avatar
The 3bar looks nothing like a honda sensor, and it does not mount where the stock sensor goes. it's a big black box that you run a vacuum line to. You'll need to leave your stock MAP sensor in place, else you win a free vacuum leak.
I have the 3bar from lightning, works great.
Old Jul 27, 2005 | 04:11 PM
jBj's Avatar
jBj
Is there any 3 bar that mounts in place of the stock map sensor?
So you just mounted your sve 3 bar wherever, splice the wires and run a vac line?
Old Jul 27, 2005 | 09:41 PM
mrDFWmechanic's Avatar
i work at a parts store and i bought a 3bar map sensor for a 97 impala ss for 35 bucks with pigtail
Old Jul 28, 2005 | 04:29 PM
jBj's Avatar
jBj
Default Re: (iROCKtheSOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iROCKtheSOHC &raquo;</TD></TR><TR><TD CLASS="quote">i work at a parts store and i bought a 3bar map sensor for a 97 impala ss for 35 bucks with pigtail</TD></TR></TABLE>
What kind?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jBj &raquo;</TD></TR><TR><TD CLASS="quote">Is there any 3 bar that mounts in place of the stock map sensor?
Old Jul 29, 2005 | 08:41 PM
jBj's Avatar
jBj
bump
