28lbs of torque right
Old Jun 25, 2006 | 10:21 AM
JLHDOHC's Avatar
Default 28lbs of torque right
I just bought a set of Eagle rods for my GSR build and was noticing that the paper sent with them stated TQ specs they are a 5/8 bolt witha 3/8 12point socket head I torque them to 28lbs with moly lube is there any special way you have to torque them down and is that tq spec right I don't have a stretch gauge so it has to be TQ please any info would help so many opinion's but no straight awser have been received.........
Old Jun 25, 2006 | 10:35 AM
JLHDOHC's Avatar
Default Re: 28lbs of torque right (JLHDOHC)
ANYONE...........
Old Jun 25, 2006 | 10:41 AM
zerovandez's Avatar
https://honda-tech.com/zerothread?id=1667296
Old Jun 25, 2006 | 12:21 PM
JLHDOHC's Avatar
Default Re: (zerovandez)
its kinda funny that you send that never got any straight awnser from that thread to many people talking about stretch gauge I need TQ SPECS I think its 28lbs i just don't wanna here that thats wrong later down the road.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zerovandez &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1667296</TD></TR></TABLE>
Old Jun 25, 2006 | 12:57 PM
nfn15037's Avatar
Default Re: (JLHDOHC)
Buy a rod bolt stretch gauge and tighten them properly. Otherwise, determine what bolt size you have and look on the sheet that comes with them to determine ARP's recomended torque value. Or of that doesn't work for you, use the goddamned search and look in archived content. There are about 28485683653587 threads about Eagle rod bolt torque.
Old Jun 25, 2006 | 10:38 PM
JLHDOHC's Avatar
Default Re: (nfn15037)
Screw you buddy I have look and searched so instead of being a dick maybe reply with a little more honda-tech attitude cause I don't need to know what a search is after I have look and there is not 2345567678998756 searches for eagle rods and even if there is I would rather discuss it before I do it. So then Mr know it all what are the specs then...... Oh and if I had the sheet I definitely would be asking...MR.Cool Guy
QUOTE=nfn15037]Buy a rod bolt stretch gauge and tighten them properly. Otherwise, determine what bolt size you have and look on the sheet that comes with them to determine ARP's recomended torque value. Or of that doesn't work for you, use the goddamned search and look in archived content. There are about 28485683653587 threads about Eagle rod bolt torque.[/QUOTE]
Old Jun 25, 2006 | 10:46 PM
bag's Avatar
bag
yeah without a stretch gauge you gotta tq it down and loosen it 3-4 times..you'll be all good..for example tq it down then loosen,tq it down then loosen,tq it down then loosen, you get the point
Old Jun 26, 2006 | 05:29 AM
JLHDOHC's Avatar
Default Re: (bag)
what if I torque it 10lbs then 15lbs then 20lbs rotated it torque them to 25lbs then rotated it and then torque it to 28lbs would that be ok cause I assembled block last night didn't realize you had to loosen then tighten will I be ok? its a boosted motor should I tear it back down and loosen them then tighten, then loosen then tighten will my oil pan gasket need to be replaced if I have to tear it down again...
Old Jun 26, 2006 | 07:20 AM
nfn15037's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JLHDOHC &raquo;</TD></TR><TR><TD CLASS="quote">Screw you buddy I have look and searched so instead of being a dick maybe reply with a little more honda-tech attitude cause I don't need to know what a search is after I have look and there is not 2345567678998756 searches for eagle rods and even if there is I would rather discuss it before I do it. So then Mr know it all what are the specs then...... Oh and if I had the sheet I definitely would be asking...MR.Cool Guy
Since you are incapable of using a search system that a toddler could master, I'll spoon feed you. And no, you don't have to torque them multiple times.
7/16" ARP 8740 - 7/16" bolt head - 63 ft lbs
7/16" ARP 2000 - 7/16" bolt head - 75 ft lbs
7/16" ARP L-19 - 1/2" bolt head - 79 ft lbs
3/8" ARP 2000 - 7/16" bolt head - 43 ft lbs
5/16" ARP 2000 - 3/8" bolt head - 28 ft lbs
https://honda-tech.com/zerothread?id=1534935
https://honda-tech.com/zerothread?id=464222
https://honda-tech.com/zerothread?id=449889
Old Jun 27, 2006 | 05:30 AM
JLHDOHC's Avatar
Thanks..............it was good
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nfn15037 &raquo;</TD></TR><TR><TD CLASS="quote">
https://honda-tech.com/zerothread?id=449889</TD></TR></TABLE>
lilsicsoul
13
Feb 15, 2010 12:43 PM
hondatuningboi96
Aug 18, 2007 06:54 PM
b00st Junkie
Honda Motorcycles
Dec 17, 2006 12:44 PM
Slava.
Jan 12, 2004 10:24 AM
Evs-One
Apr 16, 2003 05:47 PM
