Is 20w50 too thick?
Old Oct 15, 2006 | 10:58 PM
Pikachu's Avatar
Default Is 20w50 too thick?
I'm running a fully built h22 engine and I was curious whether or not 20w50(non-synthetic) is too thick to run in my engine. I found that 10w30 just burns away slowly. This car is just used for the track and pretty much nothing else. The engine is running 9 to 1 compression. My buddy told me it might destroy my bearings. That scares me a bit.
1. Will my bearings wear out running this oil?
2. Should I switch back to 10w30?
Thanks!
John
Old Oct 16, 2006 | 02:51 AM
dnbruut's Avatar
Default Re: Is 20w50 too thick? (Pikachu)
20w wont make a big difference with 10w @ 90degrees celcius
Old Oct 16, 2006 | 04:57 AM
JDogg's Avatar
Default Re: Is 20w50 too thick? (dnbruut)
it depends on how your motor was built.. you should talk to your engine builder about it.
Old Oct 16, 2006 | 06:30 AM
mike1114's Avatar
Default Re: Is 20w50 too thick? (JDogg)
I'm basing this on a daily driver but I think 20W50 is good for the summer if you live where it gets hot (I do) but in the cooler months of the year it might be a little too thick.
I just did an oil change this weekend as thought to myself, its getting colder out, maybe I should have put thinner oil in there, but it is still getting into high 80's here in the daytime so next oil change will be to thinner oil for the winter.
Drag turbo install manual says to put 20W50 during turbo install.
Modified by mike1114 at 7:30 PM 10/16/2006
Old Oct 16, 2006 | 06:44 AM
earl's Avatar
A thicker weight oil makes the oil pump work harder and does cost you a little power. If your bearing clearance is loose, you can get away with a thicker weight oil than if the clearance is tight. When it comes to oil, thicker does not always mean better.
Old Oct 16, 2006 | 06:55 AM
Mykizism's Avatar
Default Re: Is 20w50 too thick? (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote"> thicker does not always mean better. </TD></TR></TABLE>
thats not what the ladies say
Old Oct 16, 2006 | 08:42 AM
Pikachu's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">A thicker weight oil makes the oil pump work harder and does cost you a little power. If your bearing clearance is loose, you can get away with a thicker weight oil than if the clearance is tight. When it comes to oil, thicker does not always mean better. </TD></TR></TABLE>
So running thinner oil is better essentially? I'm just afraid of starving the engine of oil since it burns away driving the car hard. Guess I'll have a few quarts taking my car to the track. Thanks!
Old Oct 16, 2006 | 09:46 AM
Mykizism's Avatar
i think what earl is trying to say is that, you have to have the right oil matched to what bearing clearances you are running..
if you have really loose clearances.. ur goign to want to use a thicker oil..
if you have really tight clearances.. ur going to want to use a thinner oil..
me personally, built h22 block.. with in factory oem spec clearances... im going to run 10w-40.
Old Oct 16, 2006 | 10:02 AM
Pikachu's Avatar
Yea my clearances are tight. I'll run 10w40 on my car then. Thanks for the insight guys.
Old Oct 16, 2006 | 10:53 AM
nowtype's Avatar
Default Re: (Pikachu)
Oil is cheap. If you figure you burn 1qt every 2 weeks and a qt of oil is $3, you are talking about $78 in oil. So really in the end, I doubt you burn more than $200-250 of oil a year. Its really not that much money if you consider how much other stuff costs.
Old Oct 16, 2006 | 11:21 AM
dnbruut's Avatar
Default Re: (nowtype)
no you are right but thinner doesnt have to be better too.
the thing is the number before the w (10w-20w) is only important when the oil hasn't reached his normal working temperature jet. if you really need some thicker oil (high clearence) use some ..w50 instead of ..w40
if it burns the most oil during engine warm up then i'd sugest you'd try 20w instead of 10w this can sole your problem an it is a problem if you burn a lot of oil because you will get carbon built up.
Old Oct 16, 2006 | 11:33 AM
alterdcreations's Avatar
Default Re: (dnbruut)
I ran 0-w20 for a while. it didn't burn as much as 10-w30.
are you burning oil thru your rings or is your oil breaking its self down(smoke out of the valve cover oil cap)? are you running syntec.?
OOPS YOUR NOT. maybe you want to try syntec. mobile worked for me
Old Oct 16, 2006 | 12:36 PM
vtec.dc2's Avatar
i would stick with syntetic, much better than convetional.. people are likely to destroy their engine due to something else before oil. i switch from 5w40 during cold weather to mix of 5w40 and 15w50 during spring and 15w50 or 20w50 during summer..
johnclaunch
Jan 21, 2007 07:44 PM
jacky599r
Dec 15, 2005 09:12 AM
TimeRacer
42
Jun 7, 2005 09:17 AM
jdmCivic925
Jul 15, 2003 11:22 PM
whtrice01gsr
Jul 14, 2002 01:27 PM
