2 Simple Jackson Racing Questions
Old Mar 4, 2003 | 07:10 PM
Westsideboy's Avatar
Default 2 Simple Jackson Racing Questions
1) What is the rise rate of the stock JRSC FMU that comes with the D16 kit?
2) What is the flow rate of the "JR High Flow Fuel Pump" as offered on the website?
Old Mar 4, 2003 | 07:17 PM
zip's Avatar
zip
Default Re: 2 Simple Jackson Racing Questions (Westsideboy)
5:1 rise rate
190lph "upgrade" Walbro fuel pump
Old Mar 5, 2003 | 07:19 PM
Default Re: 2 Simple Jackson Racing Questions (zip)
Will this pump work well enough with a 450cc DSM injector set up?
Old Mar 5, 2003 | 07:50 PM
keebler65's Avatar
if you're getting bigger injectors, then you should have no need for higher than stock fuel pressure, since they will flow more instead. this is the concept behind the SMC fuel controller.
Old Mar 5, 2003 | 09:11 PM
illi Adik's Avatar
The upgrade is a 255 not 190
Old Mar 7, 2003 | 09:30 AM
Default Re: 2 Simple Jackson Racing Questions (Jackson4Door)
So, just to confirm, the JR High Flow Fuel pump as advertised off the website is a 255 lb/hr unit?
Old Mar 7, 2003 | 10:03 AM
96IntegraRS's Avatar
Walbro makes the pumps for Jackson.
There are 2 "hi-flow" models... the 317 and the 342. The 317 is what JR is selling. It is good for 85Psi. The 342 is good for 100+Psi (bad bad).
The DSM 450's run on stock pressure pumps - big injectors equals less pressure.
Old Mar 9, 2003 | 10:44 AM
illi Adik's Avatar
Yes, 255, and its made by walbro.
turbolsvtecej1
Sep 7, 2014 04:06 PM
Pfieff
Jun 30, 2003 02:30 PM
Anubyss
Apr 23, 2003 06:54 AM
HybridCoupe
Jul 6, 2002 04:44 AM
