2 bar map sensor wiring for ef with aem ems
Old Mar 25, 2005 | 08:37 AM
fqnjdmboy's Avatar
Default 2 bar map sensor wiring for ef with aem ems
Hey this is my first post in forced induction....I searched but came up with nothing on how to hook up a 2 bar map in my ef...Im running an aem ems....thanks in advance!
Old Mar 25, 2005 | 08:42 AM
liam821's Avatar
25 Year Member
Default Re: 2 bar map sensor wiring for ef with aem ems (fqnjdmboy)
The stock map sensor is a 2bar (well 1.75). You just go into the AEM EMS software and select the honda 1.75bar sensor and call it a day. To install an aftermarket 2/3 bar, you just wire it into the stock wiring, and then go into the EMS and select the right sensor. Its easy.
liam
Old Mar 25, 2005 | 09:22 AM
fqnjdmboy's Avatar
Yeah but what wires go to what?....I dont exactly know the pin locations...for both the stock map wiring and the accel 2 bar map....thanks for your help!
Old Mar 25, 2005 | 10:37 AM
liam821's Avatar
25 Year Member
Default Re: (fqnjdmboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fqnjdmboy &raquo;</TD></TR><TR><TD CLASS="quote">Yeah but what wires go to what?....I dont exactly know the pin locations...for both the stock map wiring and the accel 2 bar map....thanks for your help!</TD></TR></TABLE>
Use the pin outs on the hondata tech page, it should have everything you need.
http://hondata.com/tech3barmap.html
liam
Old Mar 25, 2005 | 01:08 PM
fqnjdmboy's Avatar
thanks that helps out a lot....
wickedEFguy
Mar 7, 2008 11:55 AM
letitroll
Aug 5, 2007 04:54 PM
buck02
Jun 26, 2005 02:18 PM
vtekthis
Apr 10, 2005 06:00 AM
nick-vti
Aug 10, 2004 09:27 PM
