2.0LS???
Old Jul 19, 2001 | 03:56 PM
Ray's Avatar
Ray
New User
Default 2.0LS???
I'm bout to resleeve my LS to 84mm that would make it the same as a sleeved B20block. Do I need to do anything else? It will be used with a B18b head. Also what is better new factory honda head studs or used arp?
Old Jul 19, 2001 | 05:07 PM
TurboInteg95's Avatar
Default Re: 2.0LS??? (Ray)
used ARPs.
Old Jul 19, 2001 | 06:02 PM
FAST94GSR's Avatar
New User
Default Re: 2.0LS??? (TurboInteg95)
I believe you'll have to do some machining to your combustion chambers and probably have to open up your headgasket some.
Old Jul 19, 2001 | 06:07 PM
b18bturbo's Avatar
Default Re: 2.0LS??? (FAST94GSR)
the 84mm wont line up with 81.5 mm head you would have machine the head gasket a little and open the combustion chamber a little to match it.
Old Jul 19, 2001 | 07:40 PM
Ray's Avatar
Ray
New User
Default Re: 2.0LS??? (b18bturbo)
why not use a b20 head gasket? also i thought a b20head is the same as a LS head
Old Jul 19, 2001 | 09:59 PM
bgod's Avatar
not related to your b18b, but a guy that goes to the shop i goto runs 84mm on his b18c block with 12:1 compression. the car's a monster to say the least.
Old Jul 20, 2001 | 12:37 AM
Ray's Avatar
Ray
New User
Default Re: 2.0LS??? (bgod)
What do you guys think about compression? I was thinking of running higher compression and less boost(I like alot of torque) for a daily driver so 9.5:1 or 10:1?
Old Jul 20, 2001 | 01:08 AM
VaporTrail's Avatar
New User
as long as your tuning methods don't consist of boost dependant regulators, boost retard modules, and check valves (ie, get a PEMS), then a higher compression setup would be great, and reliable as well.
Old Jul 20, 2001 | 01:10 AM
VaporTrail's Avatar
New User
Oh yeah, I also am a really big fan of OEM bearings, seals and such. If you really want it to be stout, Z10 Engineering makes a nifty block girdle, similar to that of the GSR/ITR's
Old Jul 20, 2001 | 01:26 AM
Ray's Avatar
Ray
New User
Default Re: 2.0LS??? (VaporTrail)
actually im gonna run with crappy fmu setup for a few months before I get hondata(hondata might not be able to mod my ecu) or Zdyne. Before standalone i'll try to be safe, 8degrees retard boost less than 10psi even with a fully built bottom.
cwest_civic_ek
Apr 23, 2007 09:19 AM
JDMGhosteg-6
Aug 24, 2005 11:49 PM
soLSvtec12kcraze
Mar 17, 2005 06:43 PM
ccsmith1999
Apr 22, 2004 06:14 PM
InfamousRS
May 2, 2002 12:58 PM
