2.0L LS/VTEC Build! (Not Finished)
Old Jun 11, 2005 | 10:55 PM
forcedinductionz's Avatar
Default 2.0L Sleeved LS/VTEC Build
Just finished up prepping my block tonight...building tommorow night..thought I might share some pictures
http://forcedinductionz.50megs.com/2.0/
Bore - 3.307"
Wall Clearance - .003"
Top Ring - .019"
Second Ring - .021"
Eagle Lightweight Crank
Eagle H Beams
9:1 Wiesco's
Never painting my block "aluminum" again, didn't expect it to be so bright
Old Jun 12, 2005 | 06:59 AM
alpha's Avatar
Default Re: 2.0L Sleeved LS/VTEC Build (forcedinductionz)
Looks like it's going to be a beast. Good luck with it.
Old Jun 12, 2005 | 07:12 AM
Rod.'s Avatar
Default Re: 2.0L Sleeved LS/VTEC Build (0x64)
looks good
Old Jun 12, 2005 | 08:35 PM
Here are some updates as of tonight
Prepped Block
Pistons of the rods, pistons/rings matched to each cylinder
Eagle Lightweight Crank cleaned and prepped
Installed main studs, and crank
GE Girdle installed with plastigauge
That is as far as I got tonight, found a broken second ring right out of the package, so gotta order another set from Wiesco on monday
Old Jun 12, 2005 | 08:41 PM
mtber's Avatar
Nice
Old Jun 12, 2005 | 09:21 PM
boosted92's Avatar
Where'd you get that block paint? Looks bling.
Old Jun 12, 2005 | 09:25 PM
gramentz's Avatar
Default Re: 2.0L Sleeved LS/VTEC Build (boosted92)
Looks good man, are you puttin the pistons in yourself? Or are you havin a friend help you? Just a heads up- if youre doin it by yourself, try and get some gloves or somethin, piston ring compressor is sharper than it looks
I work at NAPA, we sell if as Duplicolor High Heat Engine Enamel the 1200 degree stuff, it''s called "aluminum."
Old Jun 12, 2005 | 09:28 PM
boosted92's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by forcedinductionz &raquo;</TD></TR><TR><TD CLASS="quote">I work at NAPA, we sell if as Duplicolor High Heat Engine Enamel the 1200 degree stuff, it''s called "aluminum."</TD></TR></TABLE>
I figured that's what the duplicolor is I just got my new block in today, and drab green just isn't doing it for me
Old Jun 12, 2005 | 09:58 PM
OMG B16's Avatar
holy bling bling
Old Jun 12, 2005 | 11:15 PM
Si Shane's Avatar
Default Re: 2.0L Sleeved LS/VTEC Build (Sick00SiCoupe)
it looks like **** in person I did aluminum then after being totaly dissatisfied, i painted over it lightly with 'ford grey' and i got a nice kind of speckled easy grey look.
salt
Mar 2, 2006 02:56 PM
RenoRacing
Jun 3, 2004 04:46 PM
scooter
Mar 4, 2003 11:05 PM
