2" intercooler pipe??
Old Jun 13, 2006 | 05:59 PM
mike93boost's Avatar
Default 2" intercooler pipe??
should i have any concerns about using a 2" ID pipe from the turbo to the intercooler and then 2.25" ID pipe from intercooler to intake on a soon to be 400+whp d16?
im thinking the 2.25" will be fine but what about the 2" ?
Old Jun 13, 2006 | 06:02 PM
coneheadsracing's Avatar
Default Re: 2" intercooler pipe?? (mike93boost)
How big is your turbo outlet?
Old Jun 13, 2006 | 06:09 PM
Default Re: 2" intercooler pipe?? (coneheadsracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coneheadsracing &raquo;</TD></TR><TR><TD CLASS="quote">How big is your turbo outlet?</TD></TR></TABLE>
its a precision sc34 57 trim .63 a/r ball bearing watercooled.
i think the outlet is 2" isnt it? i dont have the turbo yet. it will be here this week.
Old Jun 13, 2006 | 07:06 PM
Muckman's Avatar
Moderator in Chief
If its an E cover then its 3" in, 2" out.
Old Jun 13, 2006 | 07:42 PM
Default Re: 2" intercooler pipe?? (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">If its an E cover then its 3" in, 2" out.</TD></TR></TABLE>
so if it is 2" out then that piping setup will be fine for a soon to be 400whp d16?
Old Jun 13, 2006 | 07:47 PM
platinum00's Avatar
I run 2.5 all the way. Your intercooler only has 2.25 in/out? What is it?
platinum.
Old Jun 13, 2006 | 07:51 PM
Default Re: 2" intercooler pipe?? (platinum00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 &raquo;</TD></TR><TR><TD CLASS="quote">I run 2.5 all the way. Your intercooler only has 2.25 in/out? What is it?
platinum.</TD></TR></TABLE>
greddy. it has to stay for now.
but will that 2" ID pipe be okay or should i upgrade it to 2.25" ID?
Old Jun 13, 2006 | 07:55 PM
96 GSR-T's Avatar
I ran 2" to turbo then 2.25" on my B series, I have read that it hardly makes a diff unless your over 500+hp.
Old Jun 13, 2006 | 08:34 PM
Widebody1's Avatar
IMO 2" is a pretty good restricton.... I have a friend though with 350WHP "400 in dynojet terms" in a B. He only has 2" hot side pipe.
I do belive there is a point where it hurts but i dont know what that point is. Id like to know
Old Jun 13, 2006 | 08:36 PM
94whtgsr's Avatar
on a mustang dyno too... yay ^^
Old Jun 13, 2006 | 08:40 PM
reallly though what difference does it make wether its 2" or 2.5" ??
Old Jun 13, 2006 | 08:44 PM
96 GSR-T's Avatar
Default Re: (mike93boost)
If the outlet on your turbo is 2".... i do not see a loss, air will travel faster through the smaller pipe, like i said.... i dont see a problem unless you are over 500+hp.
Old Jun 13, 2006 | 10:05 PM
red91sit's Avatar
Default Re: (96 GSR-T)
as long as the pipings equal or greater to the turbo outlet, it should be equal or less of a restriction than the turbo outlet, it seems like.
Old Jun 13, 2006 | 10:11 PM
eastbay92cx's Avatar
Default Re: (red91sit)
I can see and somewhat agree with the mentality that only as big as the turbo outlet is what you'd want to go with, but the way air flows, bends cause turbulance / restriction. With such a high goal as 400+, if you haven't already made the charge pipes, you may want to go with 2.25 of 2.5. If you already have the 2" pipes made up, go for it. Later on you could always see if you get a noticable gain from sizing up. Good luck.
edit: re-reading your post, if it's only from the turbo to the intercooler, as long as its pretty direct with smooth bends, I think you should be alright. Only one way to find out.
Old Jun 13, 2006 | 10:33 PM
red91sit's Avatar
Default Re: (eastbay92cx)
I was also just thinking, the pressure right after the turbo, like in it's outlet, is probobly higher then the rest of the system as well because its coming out there.
Old Jun 14, 2006 | 03:44 AM
VTteg's Avatar
I would think that if you switch those pipe around and have 2.5" from turbo to intercooler and 2" from intercooler to intake manifold, it might technically be better for flow.
The idea being that the cooler air would be denser and pushing it through a 2" pipe would help speed it up as it enters your intake.
Old Jun 14, 2006 | 06:02 AM
96 GSR-T's Avatar
Default Re: (VTteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTteg &raquo;</TD></TR><TR><TD CLASS="quote">I would think that if you switch those pipe around and have 2.5" from turbo to intercooler and 2" from intercooler to intake manifold, it might technically be better for flow.
The idea being that the cooler air would be denser and pushing it through a 2" pipe would help speed it up as it enters your intake. </TD></TR></TABLE>
I thought about that too, but I think that once it gets into the intercooler, you would be bottle necking it trying to re-force it through a smaller pipe.... but it would definately increase velocity. I do not think it would be preferable in my car due to the fact that I am runnin a 70mm TB and that basically takes away the whole purpose of it.
Old Jun 14, 2006 | 11:59 AM
D-meet07's Avatar
I agree with vteg. If the piping is to big coming off the turbo then you would probably see a slower spool up. Maybe it is necessary if you had a bigger turbo with a 2.5 outlet from the turbo.
Old Jun 14, 2006 | 05:52 PM
platinum00's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93boost &raquo;</TD></TR><TR><TD CLASS="quote">
but will that 2" ID pipe be okay or should i upgrade it to 2.25" ID?</TD></TR></TABLE>
2 inch to the hotside, and the size of your throttle body for the cold...
platinum.
Old Jun 14, 2006 | 06:11 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 &raquo;</TD></TR><TR><TD CLASS="quote">2 inch to the hotside, and the size of your throttle body for the cold...
yea thats what it is.. got my turbo today. just going to keep the piping the way it is..
Old Jun 14, 2006 | 06:47 PM
platinum00's Avatar
good luck on the build man.
did you get all your **** yet?
platinum.
Old Jun 14, 2006 | 06:50 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 &raquo;</TD></TR><TR><TD CLASS="quote">good luck on the build man.
i got a few of the many many parts today...the turbo for one, thanks roguemotorsports!
look here for a progress thread..
http://columbiasr.com/phpBB/viewtopic.php?t=2382
Old Jun 15, 2006 | 05:29 AM
Bailhatch's Avatar
Ive made 400whp with 2" from an e cover to the IC.
turbosol_16
Dec 24, 2006 05:39 PM
darkdemon215
11
Dec 21, 2004 04:15 PM
RACEPAK
Jul 24, 2004 12:30 PM
DubyaAye
Apr 25, 2004 10:54 AM
NeXtLeVeL_TyPe_R
Apr 17, 2002 09:38 PM
