1st time at the track boosted.
Old Jul 2, 2002 | 08:17 PM
Evil EG's Avatar
Default 1st time at the track boosted.
Well I just got back from the track and here was my best run.
r/t .886
60' 2.258
330 6.247
1/8 9.489
MPH 77.09
1000 12.277
1/4 14.634
MPH 96.22
With 6.5lbs of boost.
I was disapointed I thought for sure I would run low 14's or high 13's
But I guess its not bad for the first time at the track.
BTW- While I was there I got to see the HAHN Racecraft Neon make a 9.96 run.
I also saw the Drivers Image Civic Hatch make a 10.23 run(without Nitrous) didn't stay long enough to see there 9sec pass.
Any comments are welcome. Also what are you other turbo Integra's running?
Old Jul 2, 2002 | 09:52 PM
Dutchie's Avatar
Default Re: 1st time at the track boosted. (BVM)
I think you should be a little faster than that. Have you done a dyno run? Your 60ft isn't bad, and your mph looks a little low.
Old Jul 2, 2002 | 10:45 PM
1.8TypeR's Avatar
first time i went to the track with the turbo, i ran with stock tires and heres wat i got.
60'- 2.497
1/4- 14.009
mph- 105.98
as u can see i had major traction problems. this is at .4 bar(almost 6psi) with NA 2 1/4'' exhaust.
planning to head to the track later this month with slicks, full 3'' exhaust, and the aem tune(hopefully get it tuned next week)
Old Jul 2, 2002 | 10:53 PM
DIRep972's Avatar
Smarter than you
what elevation are u at? u r not making any power? have u dyno'd?
Old Jul 2, 2002 | 11:04 PM
TheIntegraGuy's Avatar
Default Re: 1st time at the track boosted. (DIRep972)
interesting...your times should be lower..way lower..I'm GUESSING its the elevation? Maybe weather..?
Old Jul 2, 2002 | 11:54 PM
SIK IN DA HED's Avatar
New User
Default Re: 1st time at the track boosted. (J-MiGiRL702)
well... you should be doin lower times. low 14s-high13s.
Old Jul 3, 2002 | 02:21 AM
MiraiZ's Avatar
Default Re: 1st time at the track boosted. (dlplayboy)
yup,,,I was doing 14. when I was NA
Old Jul 3, 2002 | 07:30 AM
Evil EG's Avatar
The elevation was at 632ft. It was at Route 66 dragway in joliet, il.
No I haven't dyno'd yet.
It was about 93 degrees out.
Old Jul 3, 2002 | 07:46 AM
hybrid901's Avatar
That elevation isn't that bad. There is just no mph there. Get that car tuned now. Most stock gsr's with 7-8lbs run 13.3-13.6 around here on street tires.
Old Jul 3, 2002 | 07:49 AM
autoEXturbo's Avatar
that temp could be killing you alot. But your time still seems slow. I know that when i went to the track, i was only pushing 3psi when it's set at 5psi. I ran a 15.6@90 with a 2.3 60'. I also have an automatic, so I think with some more practice you'll be seeing low 14's with ease.
Old Jul 3, 2002 | 07:54 AM
CovertFI's Avatar
not positive but you should of done better than that. did you have traction problems?
Old Jul 3, 2002 | 07:56 AM
DSF's Avatar
DSF
That mph seems very low For reference, I was running 14.4-14.6 @96-98mph w/2.4-2.6 60' times in my N/A B16 EG.
Old Jul 3, 2002 | 09:12 AM
DIRep972's Avatar
Smarter than you
check your fuel system. make sure your inline fuel pump is working. your not making any power like i said earlier. get it on a dyno and figure out why. your car should be doing 105mph. your lacking 100hp. id be willing to bet its fuel related. and id be willing to bet u r not running rich.
aaronISthrowed
Feb 15, 2007 06:46 PM
Nextelbuddy
23
Oct 4, 2003 02:46 PM
b19coupe
Feb 8, 2003 12:44 PM
Mase
Jun 28, 2002 04:42 AM
mikeSONICGSR
Nov 5, 2001 07:02 PM
