15 psi on stock LS??
Old Oct 22, 2003 | 07:24 PM
BuiltB18C1
Guest
Posts: n/a
Default 15 psi on stock LS??
anyone ran 15psi or more on their stock LS motors w/ hondata??? post numbers and how long it lasted!
Old Oct 22, 2003 | 07:28 PM
st00pid's Avatar
Default Re: 15 psi on stock LS?? (BuiltB18C1)
20 psi stock LS with a block guard 292whp 272tq 93 octane for over a year. Sprayed a 50 shot on it several times best ET was 11.6 @ 123 on the nitrous. sold the engine to someone else, its still running.
Old Oct 22, 2003 | 07:33 PM
BuiltB18C1
Guest
Posts: n/a
only 293whp?? i know people around here making that kinda power on 12 psi stock ls. but thanks for the info!!
Old Oct 22, 2003 | 07:34 PM
Chrome Pipes's Avatar
Default Re: 15 psi on stock LS?? (st00pid)
Been at 15 psi many times with no problems. Brief setup: stock LS bottom/B16A head, V-AFC, stock obd2 ecu.
See full setup click here: http://www.gtrmotorsports.net/bios/jaybio.html
Old Oct 22, 2003 | 07:44 PM
BuiltB18C1
Guest
Posts: n/a
i want to run 18psi on high boost mode and just 12 for daily driving low boost. w/ stock ls, hondata s200, 720 injectors i'll be safe?
Old Oct 22, 2003 | 07:57 PM
st00pid's Avatar
Default Re: (BuiltB18C1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BuiltB18C1 &raquo;</TD></TR><TR><TD CLASS="quote">only 293whp?? i know people around here making that kinda power on 12 psi stock ls. but thanks for the info!!</TD></TR></TABLE>
Small turbos suck.. the entire car was built with parts we had laying around the shop.
Darin D.'s Avatar
I'm running 17 psi on a stock ls longblock. 290 whp 242 ft lbs. its been about 2 months and i drive it every day no problems at all. i dont baby the car either.
Old Oct 22, 2003 | 08:00 PM
Darin D.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by st00pid &raquo;</TD></TR><TR><TD CLASS="quote">20 psi stock LS with a block guard 292whp 272tq </TD></TR></TABLE>
Damn! where is all that torque coming from? post the dyno chart if you have it.
Old Oct 22, 2003 | 08:20 PM
blown_LS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by st00pid &raquo;</TD></TR><TR><TD CLASS="quote">20 psi stock LS with a block guard 292whp 272tq 93 octane for over a year. Sprayed a 50 shot on it several times best ET was 11.6 @ 123 on the nitrous. sold the engine to someone else, its still running.</TD></TR></TABLE>
Wow man that is shitload of torque! Post dyno sheet if you got it
Old Oct 22, 2003 | 08:23 PM
InTeGrA B18b1's Avatar
Default Re: 15 psi on stock LS?? (blown_LS)
20 psi on a small turbo is like 10 psi on a big turbo but i bet theres a killer torque curve in there.
Old Oct 22, 2003 | 08:28 PM
Short Round's Avatar
Default Re: 15 psi on stock LS?? (InTeGrA B18b1)
its an LS of course it has torque
12.5 psi 300 whp 270 tq
been running 1 bar for a while now no probs
Old Oct 22, 2003 | 10:50 PM
BuiltB18C1
Guest
Posts: n/a
bump. i know the size of the turbo matters. i have something similar to t04e ball bearing.
Old Oct 22, 2003 | 11:45 PM
st00pid's Avatar
Ill try to find teh dyno.. I posted the buildup of the car over a year ago.. it was in SCC feb 03
Old Oct 22, 2003 | 11:50 PM
Mr. Softee's Avatar
Default Re: (st00pid)
isnt that your gf's car
Old Oct 23, 2003 | 04:56 AM
BuiltB18C1
Guest
Posts: n/a
bump
Old Oct 23, 2003 | 06:55 AM
civictypenos's Avatar
what size injectors are mosty of you running @ 15 psi?
Old Oct 23, 2003 | 06:56 AM
st00pid's Avatar
Default Re: (94goldjungsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr &raquo;</TD></TR><TR><TD CLASS="quote">isnt that your gf's car </TD></TR></TABLE>
yep
Old Oct 23, 2003 | 07:08 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
yep</TD></TR></TABLE>
I hope so see you soon Jason.
Old Oct 23, 2003 | 09:21 AM
BuiltB18C1
Guest
Posts: n/a
Default Re: (civictypenos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictypenos &raquo;</TD></TR><TR><TD CLASS="quote">what size injectors are mosty of you running @ 15 psi?</TD></TR></TABLE>
i am going to run 720's
Old Oct 23, 2003 | 11:34 AM
Spooled1.6L's Avatar
anyone feel that a boosted ls vtec can be as "safe" or as reliable as a boosted gsr?
Realy interested in the tourque from the ls and I think I can make good numbers. Im just scared about the head going on without problems
Old Oct 23, 2003 | 11:36 AM
Default Re: (Spooled1.6L)
And How much boost on a Boosted Ls/vtec with a drag kit would it take for me to hit 350hp to the wheels?
Old Oct 23, 2003 | 12:27 PM
TurboJesse
Guest
Posts: n/a
not a LS...but im running 1bar on a stock internal b16
Old Oct 23, 2003 | 12:43 PM
Ri5e's Avatar
Default Re: (Mpir3)
Lot of torque because timing was retarded
Old Oct 23, 2003 | 12:45 PM
Mr. Softee's Avatar
Default Re: (Mpir3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 &raquo;</TD></TR><TR><TD CLASS="quote">not a LS...but im running 1bar on a stock internal b16</TD></TR></TABLE>daym
Old Oct 23, 2003 | 01:54 PM
TurboJesse
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr &raquo;</TD></TR><TR><TD CLASS="quote">daym</TD></TR></TABLE>
Thicker headgasket though...Timing is VERY conservative and a/f is 11:9
