14b on b18a
Old Jul 4, 2005 | 02:51 PM
LShatchie's Avatar
Default 14b on b18a
Ok heres the deal, I have a b18a in my 93 hatch and I just got ahold of a 14b turbo and 440cc dsm injectors. I found a manifold for b series that will bolt up to this turbo. I still need a bov, oil lines, intercooler ect. just other small stuff, about another $400 or so. Now I understand how it all goes together, but im lost in the programming aspect of adding a turbo. I plan on only running 5-7 psi of boost, not much and I would like to know which would be the best route for me to go. Im basically asking where can I learn all this stuff that I dont know about. Like I know of hondata,uberdata, afc hack, but I dont understand exactly what it all means or is. Ive searched but cant find any info. Any comments, suggestions,questions..ect. are welcome.
Old Jul 4, 2005 | 04:47 PM
LShatchie's Avatar
Default Re: 14b on b18a (LShatchie)
why cant i ever get some answers on this site
Old Jul 4, 2005 | 04:51 PM
ryan89crx's Avatar
http://www.pgmfi.org
Old Jul 4, 2005 | 08:22 PM
LShatchie's Avatar
Default Re: (ryan89crx)
thank you
Old Jul 4, 2005 | 08:41 PM
LShatchie's Avatar
Default Re: (LShatchie)
where can i get uberdata ? it looks like the download section has been down for months
Old Jul 4, 2005 | 08:42 PM
wantboost's Avatar
Who is Mr Robot?
http://www.ecimulti.org/uberdata
Old Jul 4, 2005 | 09:07 PM
LShatchie's Avatar
Default Re: (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">http://www.ecimulti.org/uberdata</TD></TR></TABLE>
the link isnt working, all this info is overwelming .. makes me want to give up
Old Jul 4, 2005 | 09:09 PM
B6tPoweredMx3's Avatar
dont give up. If its overwelming break it down into sections and read and re-read until you fully grasp it. and if you dont understand something ask here or search.
Old Jul 4, 2005 | 09:20 PM
LShatchie's Avatar
Default Re: (B6tPoweredMx3)
Ok well once I can download uberdata, I chip my ecu and run a usb cable through it... I have to have a laptop correct and the only way to tune it is if its on a dyno? You reprogram the ecu while its still hooked up to the car right ? Basically all I want is to turbo my car and program my ecu so that my engine doesnt blow. The way I look at it is I have my car in my garage and I already have a computer out there ( its a garage/ office area) and run a long usb cable to my ecu and reprogram it right ? Or does it have to be on a dyno with a laptop in the passenger seat ? Sorry for these noob questions, its just hard to use search and find answers like this.
Old Jul 5, 2005 | 02:48 AM
kraig8's Avatar
sorry man but what your talking about is called real time programming, and uberdata does not have real time programming. if want to use RTP your going to have to use a program called crome
Old Jul 5, 2005 | 04:16 AM
0vrbst_t66's Avatar
i think you need to buy the aem,hondata,or the e-manage one of the 3 will be the best for you.when you are ready to tune get someone that knows a little more than you to tune it. pay the extra cash to save your engine from any bad tunning you would do.
Old Jul 5, 2005 | 12:00 PM
LShatchie's Avatar
Default Re: (0vrbst_t66)
So I can put the turbo on, and safely drive it with the stock ecu at like 5 psi to get it tuned somewhere?
Old Jul 5, 2005 | 12:03 PM
LShatchie's Avatar
Default Re: (kraig8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kraig8 &raquo;</TD></TR><TR><TD CLASS="quote">sorry man but what your talking about is called real time programming, and uberdata does not have real time programming. if want to use RTP your going to have to use a program called crome</TD></TR></TABLE>
can someone explain then exactly how you tune with uberdata?
Old Jul 5, 2005 | 12:34 PM
KingElli's Avatar
Search...Uberdata.
Old Jul 5, 2005 | 04:08 PM
blown_LS's Avatar
Default Re: (KingElli)
Are you using external wastegate or some different acuator arm??? I'm asking because the turbo wont run less then 8-9psi with stock actuator. Anyway i deff run that turbo at around 10psi because you wont make like 20whp gain at 5psi with that turbo.
Old Jul 5, 2005 | 09:16 PM
LShatchie's Avatar
Default Re: (blown_LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blown_LS &raquo;</TD></TR><TR><TD CLASS="quote">Are you using external wastegate or some different acuator arm??? I'm asking because the turbo wont run less then 8-9psi with stock actuator. Anyway i deff run that turbo at around 10psi because you wont make like 20whp gain at 5psi with that turbo. </TD></TR></TABLE>
Alright im using the stock internal wastegate with the stock acuator arm. So that means im automatically going to be running 8-9 psi and it wont go down or up?
The exhaust housing has cracked in the usual areas near the wastegate flapper. Do you know where i can get a new one or is it bad to run it like this if the crack isnt to bad?
Old Jul 5, 2005 | 09:19 PM
90CrxSiproject's Avatar
Hey Chris is that the turbo that we got out that junkyard together??
LShatchie's Avatar
Default Re: (90CrxSiproject)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90CrxSiproject &raquo;</TD></TR><TR><TD CLASS="quote">Hey Chris is that the turbo that we got out that junkyard together??</TD></TR></TABLE>
Yeah its that 14b lol.
Old Jul 5, 2005 | 09:20 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LShatchie &raquo;</TD></TR><TR><TD CLASS="quote">Yeah its that 14b lol.</TD></TR></TABLE>
Nice.
Old Jul 5, 2005 | 09:22 PM
Kowalski's Avatar
Read the Uberdata website and forum man... It's all there.
Old Jul 5, 2005 | 09:34 PM
LShatchie's Avatar
Default Re: (Kowalski)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kowalski &raquo;</TD></TR><TR><TD CLASS="quote">Read the Uberdata website and forum man... It's all there.</TD></TR></TABLE>
Well it looks like I have alot of reading ahead of me, or thanks to 93turbo16 he said he would do all the work for me for a resonable price... stay tuned
Old Jul 5, 2005 | 09:45 PM
Kowalski's Avatar
Well it looks like I have alot of reading ahead of me, or thanks to 93turbo16 he said he would do all the work for me for a resonable price... stay tuned </TD></TR></TABLE>
That sounds like it might be a good choice for you. It would be a good learning experience for you, because you can see everything done correctly firsthand. Learning Uberdata is, indeed a lot of work, so you should really consider having it done professionally.
Good luck with whatever you choose to do.
Soxfan4lyfe
Apr 23, 2007 07:56 PM
RicedREX
Dec 14, 2003 01:58 PM
curt801
Dec 11, 2003 06:24 AM
pdiddyparsons
Apr 3, 2003 05:01 PM
slowman
Oct 26, 2002 11:07 AM
