1400cc daily driver?
Old Jan 22, 2009 | 01:24 PM
sing's Avatar
Default 1400cc daily driver?
Planning on using RC/1400cc injectors, for a daily driver. I have a set and im pretty sure i can make it work with some tuning but wanted to know if anyone has any feed about this. Running a b16 low comp. Gt30 turbo, HONDATA S300 with 91 oct., not planning on making mad power, just 400hp. Any feed are welcome and dont ask, why i wont down grade. Just your thoughts about this and situation i might run into.
Thanks a lot.
Old Jan 22, 2009 | 01:27 PM
champLSinteg's Avatar
Default Re: 1400cc daily driver?
How are you making the b16 into 1400cc? 400hp IS "mad power" for a "1400cc" B16 on 91oct. Why are you doing this?
Old Jan 22, 2009 | 01:45 PM
boostedcivicsir's Avatar
Mr. Badwrench
i think he is talking 1400cc injectors. or am i wrong? if so you can dd them but the 1000's will probably idle circles around the 1400's.
Old Jan 22, 2009 | 02:07 PM
sing's Avatar
Edited!! Like i said, dont ask y im using 1400cc. And still u ask, ill answer for u.. Because i want to use them! :D thank you. I heard idle was going to be rough but i gotta c for myself. Maybe it just need some good tuning.
Thanks for the advices.
Old Jan 22, 2009 | 02:13 PM
Mr. Badwrench
problem is that larger injectors react slow, so they need to run a little rich, you have it in your head that you are running them, so why are you asking wether or not to?>
it seems as if you have made up your mind. it can be done but at what expense?
Old Jan 22, 2009 | 02:41 PM
jdm602's Avatar
yea you can run 1600's too for a daily driver. only thing with big injectors is that its going to idle like **** the larger you get. but to some they dont care how it idles. i know i dont.
Old Jan 22, 2009 | 02:52 PM
non-VTEC's Avatar
1400cc is way overkill for only 400whp. it will idle/cruise like **** and probably get poor fuel economy because the part throttle tune would be horrible.
sell them and go for a set of 750-880cc. or try out the new bosch 1000cc injector.
Old Jan 22, 2009 | 02:57 PM
Mr. Badwrench
re opened op would like to hear more.
Old Jan 22, 2009 | 04:57 PM
Boosted_B_Series's Avatar
Get the bosche injectors.. they can flow like a 1400 if you raise the fuel pressure and idle smooth as silk like a 680. They are the **** my friend
Old Jan 22, 2009 | 05:16 PM
jdm602's Avatar
1400 does seem like overkill if you want 400 wheel on pump gas. you dont need those big of injectors, i would say 650's or 750's. if you want more power and decide to go to a different gas like e85, e98, or q16, your gonna need bigger injectors cause you use like 30% more fuel with those fuels.
Old Jan 23, 2009 | 08:41 AM
sing's Avatar
Thanks a lot.. Ill look into the bosch injectors a bit more sounds like something i should get. But i was planning to use a different kind of gas, the reason for my use of the 1400's. Was just wondering had anyone tried them as a dialy yet... I guess im done here and found my answer....
Thanks to the help guys
antoni
Nov 13, 2018 08:16 AM
Dev15Bizz
Apr 9, 2009 03:22 PM
EFvtec Yo!
Jul 15, 2006 03:14 PM
littletriad
Oct 7, 2005 07:34 AM
95integrags-r
Jun 12, 2003 10:37 PM
