130k+
Old Dec 12, 2001 | 10:40 PM
Battousai TT52's Avatar
Default 130k+
K i've got a 94 ls w/ 130k miles and counting what needs to be done so she can handle around 10 pounds daily driven??? Also w/ 10pounds on the kit bens offering what should i be looking at in the quarter ballpark times ya know??? I want to avoid a swap at all cost cause of money and dont feel like pulling the engine. thanks all help appreciated!!
[Modified by TightTeg52, 7:41 AM 12/13/2001]
Old Dec 12, 2001 | 11:41 PM
BoM's Avatar
BoM
Default Re: 130k+ (TightTeg52)
you dont' want a swap, then REBUILD UR ****
Old Dec 12, 2001 | 11:47 PM
DLB1994's Avatar
jinxproof99 got a a b18c1 motor in his civic engine had 140k on it and he ran 11's on a stock engine tuning is the key
Old Dec 13, 2001 | 04:02 AM
D-Man's Avatar
Rebuild engine with forged pistons such as arias,JE+srp,AEM and such.thats if you dont crank boost up,if you do,u need more,such as sleeves + rods.
Old Dec 13, 2001 | 04:21 AM
teg90rs's Avatar
Default Re: 130k+ (D-Man)
What other internals besides pistons and rings needs to be changed? I know it's a good idea to replace all gaskets and seals, but would I need new valves and springs, too? I plan on boosting no more than 7 lbs.
Old Dec 13, 2001 | 07:34 AM
rtype11's Avatar
you can run 12's easy if compression is good, if not you will need to freshen the motor. for 10PSI you can run stock motor all day long
Old Dec 13, 2001 | 08:48 AM
D-Man's Avatar
Default Re: 130k+ (teg90rs)
Bring the Rods and Crank to a machine shop have it checked and get new crank and rod bearings,replace the rod bolts with new ones,pref from ARP.get a new oil pump too.
Old Dec 13, 2001 | 10:29 AM
LoudLude's Avatar
do a compression and leakdown test. This will give an idea of how your internals size up to the task.
Old Dec 13, 2001 | 04:16 PM
sa21199's Avatar
Default Re: 130k+ (LoudLude)
exactly...compression test and leakdown test should be down to see how good of condition the motor is in. Just remember you can blow up a motor with 3k miles on it just as easily as a motor with 130k. Install everything correctly and make sure the motor is getting enough fuel.
Tad
Dec 27, 2017 11:30 AM
rhdune16
May 16, 2005 09:35 AM
xstalkrx
Feb 27, 2003 06:34 AM
bluedelsol
Aug 24, 2002 02:24 PM
integra81
Nov 20, 2001 11:49 AM
