13 head gaskets in 3 years Please help!
Old Sep 25, 2007 | 03:54 PM
downeyballz's Avatar
Default 13 head gaskets in 3 years Please help!
I've been working on my eg for a few years now. And I never get the to enjoy driving it because i keep blowing head gaskets. In the car I have a B18c1 bored to 84mm with dart sleves. The deck has been been shaved dew to a overheating problem 3 years ago. The head is straight I had it checked. I've been using Cometic gaskets sence I built the motor. In the 3 years I had the motor in the car I've done about 13 head gaskets. I'm tired of doing them. I've also used arp head studs torgued to 75ftlbs with arp lube. I replace them every 2 gaskets. So I desided to line a cometic gasket up to my head and noticed that the coolent ports on the gasket (on some) where smaller then the ones on the head. Also I forgot to mension I have a gt35r turbo that is cooled be antifreeze. I have the coolent host comeing out of the back of my intake manifold to the turbo then to the head. When ever I do a head gasket I do a 1000 mile break in. no shifts over 4000. during the break in I have no problems, the car run like a dream. but after when I hit boost and bring the rpms up the temp climbs just as fast. The head gasket dosent blow till the motor gets hot. So Its not the boost. Any suggestions would be great.
Old Sep 25, 2007 | 03:57 PM
Turbo-charged's Avatar
Default Re: 13 head gaskets in 3 years Please help! (downeyballz)
who sleeved the block? ive seen time and time again where headgasket issues are caused by uneven sleeves. decking the block will not fix the problem.
Old Sep 25, 2007 | 04:10 PM
batboyvaj's Avatar
have you tried using a ge gasket?
Old Sep 25, 2007 | 04:31 PM
boostismycrack's Avatar
E-thug
Default Re: (batboyvaj)
I feel u bro, i had the same issues. My guess is a sunk sleeve. Take the car to someone who knows what they are doing and have them check it...
Old Sep 25, 2007 | 04:59 PM
ek_chris's Avatar
Sunken sleeve will def. cause this. I've used cometic gaskets plenty of times, so its not the gasket, either its a sunken sleeve, warped deck (but you said they were within spec.) so my bet would be sleeves
Old Sep 25, 2007 | 05:13 PM
Migrana's Avatar
Default Re: (ek_chris)
did you check the head for any crack
Old Sep 25, 2007 | 05:20 PM
Migrana's Avatar
i had the same problem driving normal good. i hit boost and i bring the rpm up the temp clime just as fast
Old Sep 25, 2007 | 05:26 PM
building boost's Avatar
lol i probably would've asked this question after the third gasket. sounds like you have a sunken sleeve. get the block checked by a machine shop, preferably the one that didn't sleeve your block.
Old Sep 25, 2007 | 06:02 PM
drtysohc's Avatar
+1 on sunken sleeve
Old Sep 26, 2007 | 04:03 AM
morgan@synapse motorsport's Avatar
who sleeved the motor?
out of 13 cometic gaskets i would figure maybe 1 or 2 might work, so its most likely a sunken sleeve like everyone is suggesting.
Old Sep 26, 2007 | 08:52 AM
locash's Avatar
I think we are overlooking one thing.. Who tuned the motor? Is it possible that you have severe detonation under boost that is causing the weak link to give?
Old Sep 26, 2007 | 09:15 AM
Unsivil_audio's Avatar
Ditch the cometic, I've had nothing but bad experiences with them. I run a $30 Felpro MLS now, works like a charm.
Old Sep 26, 2007 | 09:18 AM
havok hybrid's Avatar
Default Re: 13 head gaskets in 3 years Please help! (locash)
take the turbo off... and beat up on it if you really want to know if its boost related.
OEM G.E. headgasket
Have your tired a Leak down test?
Old Sep 26, 2007 | 09:35 AM
fast2camciv's Avatar
13 headgaskets! i surely would have given up by then lol
i only run oem gaskets as well.
Old Sep 26, 2007 | 12:10 PM
batboyvaj's Avatar
so in the last 3 years you have spend $1,170 on gaskets??? dang. i feel bad for you. cometics aren't cheap either (~$90)
Old Sep 26, 2007 | 01:24 PM
eh3 93's Avatar
I would just ditch the motor by now. Wouldnt want to take the chance again.
Old Sep 26, 2007 | 04:02 PM
PHDZINE's Avatar
Default Re: (eh3 93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by locash &raquo;</TD></TR><TR><TD CLASS="quote">I think we are overlooking one thing.. Who tuned the motor? Is it possible that you have severe detonation under boost that is causing the weak link to give?</TD></TR></TABLE>
Check your tune!!!
Old Sep 26, 2007 | 04:10 PM
1992Si's Avatar
There is a famous saying, "it's all in the tune"
Next time the head is off check the height of each sleeve.
Look in the exhaust ports for small dingle ***** they are a sign of detonation.
When you break torque on the studs, do any of the nuts seem lose?
Old Sep 26, 2007 | 06:36 PM
Default Re: (1992Si)
does anyone make 84mm oem style gaskets, or cut oem gaskets to fit?
Old Sep 26, 2007 | 06:39 PM
Default Re: (downeyballz)
if t was a sunken sleeve then wouldnt it overheat all of the time? with the last headgasket the car drove 1000mi during the breakin and didnt overheat.
Old Sep 26, 2007 | 08:14 PM
Dunc's Avatar
BCICAN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek_chris &raquo;</TD></TR><TR><TD CLASS="quote">Sunken sleeve will def. cause this. I've used cometic gaskets plenty of times, so its not the gasket, either its a sunken sleeve, warped deck (but you said they were within spec.) so my bet would be sleeves</TD></TR></TABLE>
One may think this...but I'm definitely going to side with trying a GE gasket. I had the same problem and everything was within spec if not perfect. Changed my 2nd Cometic gasket to a GE gasket, and gee go figure the problem vanished.
Cometic Gasket
OEM G.E. Gasket
Old Sep 26, 2007 | 08:44 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
ballin'!
make a shirt out of old head gaskets. when someone asks you what the hell you're wearing, be like "what do you care? you can't afford this! cometic, playa! 100% MLS gasket! $1300"
they'll be all up ons.
EDIT: sex panther cologne not needed.
Vtec04
Engine Machining & Assembly
11
Oct 31, 2017 09:26 AM
b16a27
Nov 25, 2008 03:11 PM
panda_eh2
Nov 5, 2007 10:08 AM
austincrx
Sep 7, 2006 09:49 AM
