1000cc injector question.
Ok here is the deal, im planning on making 300-380hp on 1000cc injectors.
and im running a gt35R turbo with 3indownpipe and later in the future is planning to go bigger with better internals and more boost. Just want to buy it and run it now so i won't have to switch it out later...
If you question is "Can I make 300-380whp with 1000cc injectors?" The answer is yes.
You can achieve that on pump gas or e85. Depending on your plans for "going bigger" you may need more injector in the future.
My Injector Dynamics 1000's maxed out at 521whp on e85.
wow must be a pumpm issue because ive made 650 on rc1000's and e85
the 1000's are fine man, and will give you the opertunity to make more power in the future
Interesting.. It may be pump related because I'm running an a1000 and they dont like high base pressures. I just went ahead and bought ID2000's
I was suprised that they ran out of fuel so fast myself since I had seen people making 600 on ethanol.
