a vtec enabled p06 and hondata?
I have a p06 vtec enabled that was socketted for a chip to work with crome. I now want to install the hondata s300. Will it work with the vtec functioning correct? On the website it says a standard p06 can be done but without vtec.
Hondata is referring to using an alternate output with a relay to activate vtec on a p06 that doesn't have vtec hardware added to it to use the standard a4 vtec solenoid output.
specialedition
May 19, 2005 12:11 AM
