tuning lstvec
Old Oct 31, 2008 | 11:51 AM
dirtyharryhatch's Avatar
A Digital Frontier
Default tuning lstvec
ok so my friend has an lsvtec and its running a p28 and i told him to chip it and tune it on crome just so its safe and u can get a rev limiter where u stop making power and set ur vtec where its supposed to. The tuner said theres no point in tuning it cause its just a stock lsvtec? is he right or wrong? and if he does tune it will it really be all that much safer?
o forgot what he has done is:
blox intake manifold
no name fuel pressure regulator
intake
exhaust
gsr head
Old Oct 31, 2008 | 02:12 PM
mtber's Avatar
Default Re: tuning lstvec (dirtyharryhatch)
It would be ideal to chip the ecu considering he is running a stock p28 fuel & ignition map.
A revlimit of 8400 rpms would be ideal with vtec at around 5000 rpms.
Old Nov 1, 2008 | 10:41 AM
MadScientistMatt's Avatar
Not only do you need a new tune, you need a different tuner. A "stock lsvtec" is a contradiction in terms, and having a D16 ECU pretty much guarantees your tune won't be optimal.
Old Nov 1, 2008 | 03:36 PM
MazdaSpeedster's Avatar
Default Re: tuning lstvec (MadScientistMatt)
why would u want such a high rev limiter? lsvtec doesnt magically rev higher than a gsr in any means or is safer.
but yes chip the ecu (hondata, chrome) etc and tune it to the car
Old Nov 2, 2008 | 09:21 AM
mtber's Avatar
Default Re: tuning lstvec (MazdaSpeedster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MazdaSpeedster &raquo;</TD></TR><TR><TD CLASS="quote">why would u want such a high rev limiter? lsvtec doesnt magically rev higher than a gsr in any means or is safer.
but yes chip the ecu (hondata, chrome) etc and tune it to the car</TD></TR></TABLE>
Stock revlimit of a gsr is 8200 rpms. An ls/vtec with a revlimit of 8400 rpms is probably the highest you should have considering the motor will make peak power at approximately 8100-8400 rpms depending on a few things (exhaust,header,im)
Old Nov 4, 2008 | 10:42 AM
neoc03's Avatar
Get a new tuner. There is no such thing as a stock LS/VTEC.
Old Nov 4, 2008 | 09:01 PM
A Digital Frontier
thats what i told him to tune the car so it can run how its supposed to not on a single cam fuel and ignition map
AkEuro_R
Apr 27, 2004 04:00 PM
JFG Kevin
Apr 20, 2004 10:37 AM
geminis2k
Jan 10, 2003 11:55 AM
Vanilla4215
Apr 25, 2002 12:35 AM
