Solid CEL with Ostrich 2.0, wtf?
Old Jul 4, 2008 | 07:14 AM
HiProfile's Avatar
Default Solid CEL with Ostrich 2.0, wtf?
So after fighting with it to cure the "unable to connect" issue in Crome, I get it uploaded and pluged into my P28. Solid CEL no matter what I do.
I took out the chip (which has the exact same BIN on it) and put it in red stripe closest to the DL header. Ostrich was set to 28/28 on the switches. I've actually read off the Ostrich and used CRC to verify its the same as the BIN I started with. It has to be somewhere between it's memory and the ecu's header.
I can't think of anything, so is there something I'm missing??
Old Jul 4, 2008 | 09:03 AM
mtber's Avatar
Default Re: Solid CEL with Ostrich 2.0, wtf? (HiProfile)
Did you remove the checksum from the binary file ?
If this was the issue, your welcome
Old Jul 5, 2008 | 08:20 AM
HiProfile's Avatar
Default Re: Solid CEL with Ostrich 2.0, wtf? (mtber)
I've done it once, and more than once. I've taken working BIN's that work perfect on chips, but fail on the Ostrich. Also as mentioned, I've taken the BIN off the Ostrich, burned to chip, and it works.
I'm probably going to call them & try a replacement. This thing has seriously wasted more of my time than all of the chip-burning I've done in my entire life.
Old Jul 5, 2008 | 10:03 AM
maddog20's Avatar
what are your settings? buadrate,latency?
Old Jul 5, 2008 | 10:00 PM
HiProfile's Avatar
Default Re: Solid CEL with Ostrich 2.0, wtf? (maddog20)
Its set to whatever it gives me on auto detect. IIRC its 920k/8/off/1; tried latency 1 & 16.
I really don't think its the up/downloading portion of the Ostrich, as I can D/L the BIN in working form. It just doesn't seem to supply the socket with what it needs.
Old Jul 5, 2008 | 10:36 PM
mtber's Avatar
What software are you using to write to the ostrich with ?
Old Jul 7, 2008 | 01:35 PM
HiProfile's Avatar
Crome Free v1.5. I have a license to Pro, but I can't get a reg string til John crawls out of his hole. Now that I recall, it worked fine with the EmUtility, but whenever I use that, I have to reset the Ostrich w/Tuner RT Pro.
Old Jul 7, 2008 | 04:36 PM
98vtec's Avatar
moderator emeritus
if you payed with paypal, get your money back and buy ectune. Its on sale right now too
Old Jul 8, 2008 | 06:49 AM
HiProfile's Avatar
Default Re: Solid CEL with Ostrich 2.0, wtf? (98vtec)
I paid for it in 2006, so I'm not sure that will exactly work.
I'm almost thinking its Crome that won't upload correctly. Some people say they've had Free work in the past, some say it isn't supposed to. I guess I'll just use EmUtility for faster uploads. I can make a macro that will do all the saving/uploading with one keystroke.
Old Jul 21, 2008 | 01:37 PM
leoaa777's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">Did you remove the checksum from the binary file ?
If this was the issue, your welcome </TD></TR></TABLE>
I am also having this issue. ostrich 2.0 works and I hav sent maps and read maps from the ecu. I just have a solid cel as soon as i flip the key. I removed the checksum from the file.
Q.. should i remove it before I connect it to the ostrich?
help?
Old Jul 21, 2008 | 03:09 PM
mtber's Avatar
Default Re: Solid CEL with Ostrich 2.0, wtf? (leoaa777)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by leoaa777 &raquo;</TD></TR><TR><TD CLASS="quote">
help?</TD></TR></TABLE>
Correct
Old Jul 21, 2008 | 05:26 PM
leoaa777's Avatar
Correct</TD></TR></TABLE>
I did that and I am using the JDM P30 as per moates.net instructions. Had remote help and still had a solid CEL.
Now, they told me to ship it back to them and they will check it.
or the guy that socketed my ecu sucks..
which one?
Old Jul 22, 2008 | 11:38 AM
leoaa777's Avatar
I just noticed taht there are NO ceramic capacitors in C51 nor C52.
Did he forget or what&gt;? Does that cause my CEL?
Old Aug 27, 2008 | 07:35 AM
HiProfile's Avatar
Just thought I'd update this. I checked it with Crome GOLD, and it gives a solid CEL every time. Then I ordered a new Ostrich, and this one works fine. Turns out the old Ostrich (never really used!) does not output any data through the cable/pin header. So...I'm sending it back as the new one, since they have a 30day no-hassel return policy. Seriously, I would think they'd test each one before it left the factory...
So if you ever read this leoaa777, its probably your Ostrich.
Old Sep 1, 2008 | 06:52 AM
zccr-xsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maddog20 &raquo;</TD></TR><TR><TD CLASS="quote">what are your settings? buadrate,latency?</TD></TR></TABLE>
thats what i was wondering,and try shutting off the high speed?
shermanyang
13
Aug 22, 2013 07:34 PM
cec12789
Sep 23, 2011 02:07 PM
dividedas1
14
Dec 10, 2008 04:35 AM
mattEG
Jul 22, 2005 02:21 PM
