s300 tables
IF i get some cams that delete the vtAk lobe or even if i locked the vtec rocker into action, would i just from then on out tune the "low speed" tables in s300? and never touch the high speed?
I would think you'd have to re-tune the entire range! As that will change your entire Torque Curve. Your going to be using differant Sites then the Normal Old path at WOT.
I have never Tuned a Car, that is just my opinion. GL to U with it though...
im fully aware of all of that, i tune my own car at the track. just didn't know if it from then on out is tuned from one table instead of both tables still for some reason i dont know.
