S300 boost control problems, no control!
Old Dec 12, 2008 | 07:20 PM
mrbsponge's Avatar
Default S300 boost control problems, no control!
Had my boost control components installed on my p28 s300, i have all the right selections checked, as i was just testing it with a fixed duty cycle
problem is i only get gate pressure of 18psi. doesnt matter if it is set to zero or 100%
my question is, is there a way to "test" any of these installed components, such as continuity or ohm out any of the resistors?
just dont want to have to send it back and have it all done again.
any help is greatly appreciated
Old Dec 12, 2008 | 08:13 PM
mtber's Avatar
Who did you have install the components ?
What color are the resistors at r70 and r71 ?
What does the transistor at q20 say ?
What does the transistor at q29 say ?
Did you properly run 12 volts switched to one side of the solenoid & run the other side of the solenoid to a11 ?
Old Dec 13, 2008 | 05:50 AM
mrbsponge's Avatar
lemme take a look at it when i get back to the shop john, i figured if anyone you would know
Old Dec 13, 2008 | 10:35 AM
alpha's Avatar
The Hell with the boost control. I just want to know what you made at 18lbs I'm feeling a little left out. If I come up to Alabama next week I am going to bust y0 ***, lol
Old Dec 13, 2008 | 03:16 PM
mrbsponge's Avatar
hahaha
at 18.6psi it made 569hp
Old Dec 14, 2008 | 06:25 PM
BoostedEgHatchFl's Avatar
I don't have any good info for you bro, but the car is amazing
jure
Aug 21, 2009 07:08 PM
imationdawg
Jul 22, 2009 05:24 PM
'Lude01
Jul 10, 2007 06:15 AM
