retune question
Old Jan 5, 2013 | 07:37 AM
CGcivicGSR's Avatar
Default retune question
Okay I got a h22 eg hatch turbo running s300 ive already got car tunned but over the winter I decided to do some upgrades I put two and a half inch intercooler piping cause in 2 spots I had only 2" piping. Also had to make a new downpipe cause old one cracked and I was gonna run skunk2 70mm throttle body but when I called to make an apt I found out that dentsport is no longer in business closing down... my question is will I need a retune with half inch bigger intercooler piping and a new downpipe same size
Old Jan 5, 2013 | 11:25 AM
GhostAccord's Avatar
Default Re: retune question
You should be safe with those upgrades! As long as you are not adding boost or fuel or enlarging/changing the exhaust velocity/flow it will run of your previous tune.
Old Jan 7, 2013 | 03:28 AM
CGcivicGSR's Avatar
Okay great thanks for the quick response ...now if I installed my throttle body would that change my exhaust velocity I'm assuming more Air in more air out would I need to retune if I installed my TB..I just found out dentsport is going to be open till the end of the month soo I would have time to schedule a retune if needed im butthurt there closing down matt and all the guys at dentsport are great people hopefully they move on to bigger and better
Ron Burgandy
Jul 21, 2014 11:58 AM
jbell
Nov 15, 2008 12:54 PM
BB6-213
Dec 9, 2006 03:26 PM
jdmfun99
Dec 6, 2004 02:36 PM
DownBoyDown
Dec 2, 2003 06:12 PM
