reading 5volt lsu 4.9 sensors
Old Jan 21, 2016 | 01:42 AM
barraea's Avatar
Default reading 5volt lsu 4.9 sensors
Just wondering is it possible to read a Bosch lsu4.9 sensor with just one wire on the "wideband" controller as my controller only has one wire input but has the option for narrow band or 5 volt sensor
I am unsure what to do with the heater though ?
Any help would be appreciated thank you
Old Jan 21, 2016 | 05:30 AM
Masterl1nk's Avatar
Default Re: reading 5volt lsu 4.9 sensors
What kind of controller are you using? LSU 4.9 sensors must be connected to LSU 4.9 ready controllers
Old Jan 21, 2016 | 08:44 PM
barraea's Avatar
I am to ashamed too even say but it's a defi advance zd style 10 in one guage but it has the option to select if you are connecting a 5volt or 1.2v sensor but only one wire is allocated to the air fuel option on the guage
Old Jan 22, 2016 | 07:49 AM
Flr Power's Avatar
No it will not work since it requires the controller to properly heat the sensor at the right temperature.
Old Jan 23, 2016 | 11:36 PM
barraea's Avatar
Well I've found a few online apps with a audrino based board which utilizes Android phones etc i wonder if there any good
Old Jan 26, 2016 | 06:46 AM
spAdam's Avatar
Loved
Community Favorite
OP, I'm confused as to what you're trying to accomplish. Are you just trying to display the AFR on your Defi unit? What wideband controller are you running? It seem like you might be trying to run straight from the sensor itself to your display, the answer in that case is no, it won't work.
Old Jan 26, 2016 | 04:57 PM
v4lu3s's Avatar
RTFM
that gauge will work fine. you use the 5v output wire from the windeband controller that the lsu 4.9 needs to properly work. which wideband system are you using?
Old Jan 26, 2016 | 06:04 PM
GhostAccord's Avatar
He does not have a controller. He has a gauge and an LSU O2 sensor.
Never used one myself. Post up a link to what you have found and someone might be able to chime in on if it's worth it or not.
Old Jan 26, 2016 | 06:39 PM
spAdam's Avatar
Loved
Community Favorite
That's what I got out of his post too.
Old Jan 26, 2016 | 10:33 PM
barraea's Avatar
Looks like i learnt the hard way i didn't realize a wideband controller was needed as well as the guage sorry for the time waste
Old Jan 27, 2016 | 06:39 AM
spAdam's Avatar
Loved
Community Favorite
Well, you have an extra sensor now. Just make sure you get a controller that uses a 4.9. Most of the good ones are moving over from the 4.2 if they haven't already. It's an awesome sensor.
Old Jan 27, 2016 | 07:18 AM
^X2
Haven't had an issue with mine yet, 60k on it. (Knocks on wood) Ran a fresh air calibration @ 40k but it didn't need it.
Old Jan 27, 2016 | 07:25 AM
spAdam's Avatar
Loved
Community Favorite
They do just fine on big boy race cars too, and they're super fast.
Old Jan 27, 2016 | 06:55 PM
barraea's Avatar
Originally Posted by GhostAccord
^X2
Sensor was bought to tune a simple 4.0litre ford straight 6 motor on stock internals all it'll make is 280rwkw n that's pushing to limit that's sad isn't it dual cam 4litre n that is all lol
Old Jan 28, 2016 | 04:16 PM
I'm currently using one of mine to play around with an N/A push rod GM 3.4L 90*V6. I'll be lucky to hit 250WHP to the front wheels. They are a great sensor no matter what the engine.
Old Jan 28, 2016 | 11:42 PM
barraea's Avatar
It's amazing these honda motors how much out put per litre we get. ..
So heater aside i can't just power the sensor then connect up the ref wire to this guage ?
I'm cheaper to ruin a sensor then to even do a single dyno power run here in Australia
Old Jan 29, 2016 | 04:16 AM
spAdam's Avatar
Loved
Community Favorite
No. That's just not how the sensor works at all. It has to be conditioned through a calibrated piece of hardware.
Old Jan 29, 2016 | 04:17 AM
barraea's Avatar
Got you i thought it was only calibrating the heater but Much more
rockseeb
Jun 28, 2017 11:44 AM
barraea
Engine Management and Tuning
Jan 26, 2016 10:44 PM
sonno
12
Apr 12, 2014 03:05 AM
gworthyunit
Aug 30, 2006 04:01 PM
Jason kiDD
Feb 5, 2002 06:55 AM
