Question Regarding Crome
Old May 18, 2011 | 11:05 AM
bmxkills's Avatar
Default Question Regarding Crome
Anyways, I am going to order a wideband within this next month, and I would also like to try a different tune. I am currently using a street tuned chip my buddy and I made (he's street tuned numerous cars). The car runs great, but I feel it has more potential, and could be leaned out more. I had the car dyno'd, and even Dennis at Hybrid said the car has potential to put out a bit more power with a different tune. He suggested a "fattened" up B16A ecu, because I am running a GSR block with P30 pistons, a stock B16 head, RMF header, and Professional Products Intake Manifold. However, Chris at Xenecron suggested a stock P72 basemap. My question is which should I start with, and why. Also, how do I "fatten up" a map. What numbers am I looking for in the tables... Any help would be appreciated.
Old May 18, 2011 | 01:02 PM
Julio@Bisimoto's Avatar
Default Re: Question Regarding Crome
I recommend to go dyno tune with an appropriate tuner than will be able to properly setup your air/fuel and ignition maps properly rather than just guessing with differnt maps.
Old May 18, 2011 | 05:32 PM
bmxkills's Avatar
Thanks for the reply. I plan to do that at the end of summer, but the thing is, I've already been driving this motor with my street tuned chip for a few thousand miles. It's my DD, so I NEED an ECU. Either ECU couldn't be any worse for my motor as they are similar and both recommended by many and especially these two people. So I'd like to toy around with both until the end of summer when I get my cams and valve train.
Old May 18, 2011 | 08:18 PM
mtber's Avatar
Why don't you just have your buddy street tune your car (assuming he has a wideband)?
Concerning a your original question, without a wideband, don't even waste your time trying to make your own tune.
Your next best solution is to run a basemap specifically from a vehicle like yours: http://www.phearable.net/shoppingcar...emap-p-60.html
Old May 18, 2011 | 09:37 PM
bmxkills's Avatar
That's what I'm doing... I'd like to know which would be better to start with, a P72 map on my P28, or a "fattened" P30 map on my P28. To START with... I've been using a P73 map, but I feel is too rich, which is why I'd like to start back at point one.
Old May 18, 2011 | 10:08 PM
GSRCRXsi's Avatar
if you arent using the IAB butterflies, dont use the p72 map IMO.
my b18c was tuned from a p30 base map.
Old May 18, 2011 | 10:21 PM
HRTuning's Avatar
Actually, the P72 maps with smoothing applied in the RPM range where IAB would kick in is still ideal. The P30 map sucks for the GSR engine.
Old May 18, 2011 | 11:51 PM
GSRCRXsi's Avatar
why? a number in a cell is a number in a cell.
Old May 19, 2011 | 06:58 AM
HRTuning's Avatar
If you want to retune the entire map, then sure you can start with whatever maps you want.
Old May 19, 2011 | 12:08 PM
bmxkills's Avatar
This is where I'm stuck lol. It doesn't matter if I put the P72 map on the P28, the IAB won't work without modification, which is fine because I don't have them. But, Dennis and a few others said that they prefer P30 maps to start with, then play from there. I believe this would be better for me, because I am basically a B16A with a GSR crank, so for some reason, I see a P30 map being a better choice. Then again, Chris from Xenecron knows his **** lol. In for more info...
Old May 19, 2011 | 11:06 PM
mouab18c1's Avatar
I just made a basemap for my buddies GSR with a p30 base since he no longer has the IAB's. For some reason it would idle like ****. I looked over the the fuel and ignition maps. Everything looked smooth but wasn't running properly. I was debating on using the p72 base just for ***** and giggle but not possible to smooth anything out since he has no Wideband.
I would say use a p30 base but use copy the gsr maps onto the p30. Might have him try that out.
Old May 19, 2011 | 11:23 PM
GSRCRXsi's Avatar
id say its something else. my gsr motor (ITR manifold, no IABs) its tuned from a P30 basemap and it idles fine.
Old May 19, 2011 | 11:53 PM
bmxkills's Avatar
Alright so more leaning towards the P30... Any reasons why you guys chose P30? Would It be beneficial to use the fuel multiplier tool to change fuel from 1.6l to 1.8l to start with?
Old May 20, 2011 | 12:52 AM
mouab18c1's Avatar
That's what I was saying. His car idles fine with my ITR bin I tuned my car on while I was still running on Crome. So it kinda gave me the question mark.
Old May 20, 2011 | 12:54 AM
mouab18c1's Avatar
It's just a p30 base. You copy and paste the p72 maps onto it making it a p72 map that eliminates the secondary IAB's supported by the stock gsr IM.
Here is what it looks like. p72 maps on a p30 base.
Old May 20, 2011 | 12:27 PM
bmxkills's Avatar
^I already did that, I read Chris' post on how to do that, the part where I questioned it was the cam ignition. Should I use P72 High and Low Cam Fuel, and keep the P30 High and Low Ignition? After all I am still using a stock P30 head...
race2live
Engine Management and Tuning
Aug 28, 2011 11:24 PM
mikeSMASHES
Jun 26, 2010 02:59 AM
adam00
Jan 25, 2009 07:26 AM
namewasdallas
Jan 20, 2009 05:46 AM
95cxhatch
Feb 25, 2005 02:14 PM
