P0685 Code Need Help!!!
Old Jul 20, 2009 | 04:51 PM
ATLTSX's Avatar
Default P0685 Code Need Help!!!
I have a 2004 Acura TSX. I just recently went turbo. I'm running Hondata Kpro (Consides of Reflashed TSX ECU and RSX Type S ECU). Everything was running fine. A couple days ago when I was going into boost i got a CEL. The code that came up was P0685. This is ECM/PCM Power Relay Control Circuit/Open. Kpro is not showing any CEL so it has to be in the TSX ECU. I took the TSX ECU out to make sure that the Board wasn't burnt. Plugged everything back in and i got 1 run where it ran fine. Came up to the next light and it did it again.
Any thoughts? I'm trying to get this fixed to make it to IA.
Thanks.
Old Oct 3, 2016 | 05:04 AM
bansell's Avatar
Default Re: P0685 Code Need Help!!!
Very old, but did you ever figure this one out?
SolScifen
May 19, 2013 11:35 AM
jltucker31
Mar 9, 2009 03:50 PM
Brewer
Jul 7, 2004 01:49 PM
racerxadam
Jan 13, 2002 08:37 PM
